Code 7 TPS OVER and Over Again????????? HElP
I got a 99 Ex coupe auto , in the last 8 months I have replaced about 3 TPS's. I put them all on correctly, checked them with a mutlimeter, after 2-3 months I get code 7 ... any suggestions?
yea i reset the ecu, never heard of deleting a code with a scanner, I'm mainly concerned with what is causing my tps's to fail...
if you are just disconnecting the battery to reset your ECU then you are not deleting the code. you need a scantool to delete codes on an OBD2 vehicle
there is a 7.5 amp fuse called the radio/back up fuse that will reset the code. before that check the tps voltage by back probing the harness. it should be between .45 and .48 if not adjust
OBD2 computer modules have an internal battery to save such codes. Just simply disconnecting the battery will not delete the code. Unless you leave it disconnected long enough for the internal battery to die.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol »</TD></TR><TR><TD CLASS="quote">OBD2 computer modules have an internal battery to save such codes. Just simply disconnecting the battery will not delete the code. Unless you leave it disconnected long enough for the internal battery to die.</TD></TR></TABLE>
damn obd2 system for you
Oh yeah, sure about that???
How about you post a pic of the internal battery!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol »</TD></TR><TR><TD CLASS="quote">I just might do that.....I have a few lying around here at work
afterall I an an Acura Tech</TD></TR></TABLE>
LOL...I also had a VW tech tell me I could not set TPS voltage with a multimeter...but I did
You being an Acura Tech means nothing!
Again, prove it, since I have had 0 problems getting rid of a code while removing power from the ecu totally
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges »</TD></TR><TR><TD CLASS="quote">
bwaaaahahahaha, my sides hurt. He probably said that because most german vehicles do not have an adjustable TPS. I have been building and working on Porsche race cars and street cars for the past few months. (they are a pain in the a$$)
</TD></TR></TABLE>bwaaaahahahaha, my sides hurt. He probably said that because most german vehicles do not have an adjustable TPS. I have been building and working on Porsche race cars and street cars for the past few months. (they are a pain in the a$$)
