Code 7 TPS OVER and Over Again????????? HElP
Old Jul 27, 2005 | 07:39 PM
sporty240's Avatar
Default Code 7 TPS OVER and Over Again????????? HElP
I got a 99 Ex coupe auto , in the last 8 months I have replaced about 3 TPS's. I put them all on correctly, checked them with a mutlimeter, after 2-3 months I get code 7 ... any suggestions?
Old Jul 27, 2005 | 08:07 PM
Fobtions's Avatar
Default Re: Code 7 TPS OVER and Over Again????????? HElP (sporty240)
u gotta delete that code in the computer. obd2 stores certain codes and requires a scanner to erase that one.
Old Jul 27, 2005 | 10:07 PM
sporty240's Avatar
yea i reset the ecu, never heard of deleting a code with a scanner, I'm mainly concerned with what is causing my tps's to fail...
Old Jul 27, 2005 | 11:13 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Ever think maybe its not your TPS? Has your car gotten worse? or the same as before?
Old Jul 28, 2005 | 07:53 AM
sporty240's Avatar
Default Re: Code 7 TPS OVER and Over Again????????? HElP (JDM_Ej)
usually I change the TPS, set up the voltage, reset the ecu, drive it for 2-3 months then it goes bad...
Old Jul 28, 2005 | 11:05 AM
Sliced Beard's Avatar
if you are just disconnecting the battery to reset your ECU then you are not deleting the code. you need a scantool to delete codes on an OBD2 vehicle
Old Jul 28, 2005 | 02:46 PM
rainforest's Avatar
Default Re: Code 7 TPS OVER and Over Again????????? HElP (DirtySol)
there is a 7.5 amp fuse called the radio/back up fuse that will reset the code. before that check the tps voltage by back probing the harness. it should be between .45 and .48 if not adjust
Old Jul 30, 2005 | 08:18 AM
Default Re: Code 7 TPS OVER and Over Again????????? HElP (rainforest)
OBD2 computer modules have an internal battery to save such codes. Just simply disconnecting the battery will not delete the code. Unless you leave it disconnected long enough for the internal battery to die.
Old Jul 30, 2005 | 05:43 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">OBD2 computer modules have an internal battery to save such codes. Just simply disconnecting the battery will not delete the code. Unless you leave it disconnected long enough for the internal battery to die.</TD></TR></TABLE>
damn obd2 system for you
Old Aug 1, 2005 | 08:47 AM
civic-4-ges's Avatar
Oh yeah, sure about that???
How about you post a pic of the internal battery!
Old Aug 1, 2005 | 08:50 AM
Default Re: Code 7 TPS OVER and Over Again????????? HElP (civic-4-ges)
I just might do that.....I have a few lying around here at work
afterall I an an Acura Tech
Old Aug 1, 2005 | 08:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">I just might do that.....I have a few lying around here at work
afterall I an an Acura Tech</TD></TR></TABLE>
LOL...I also had a VW tech tell me I could not set TPS voltage with a multimeter...but I did
You being an Acura Tech means nothing!
Again, prove it, since I have had 0 problems getting rid of a code while removing power from the ecu totally
Old Aug 1, 2005 | 01:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">
bwaaaahahahaha, my sides hurt. He probably said that because most german vehicles do not have an adjustable TPS. I have been building and working on Porsche race cars and street cars for the past few months. (they are a pain in the a$$)
Old Aug 1, 2005 | 08:15 PM
sporty240's Avatar
I got it scanned today and
they got this ---&gt; P0122 Throttle Position (TP) Sensor Circuit Low Input
Old Aug 2, 2005 | 11:42 AM
check to see if you have any breaks in the wires/harness and check to see if the connector is corroded
RACEPAK
Dec 3, 2005 02:55 AM
RACING INTEGRATION
Oct 12, 2004 02:40 PM
maximedx
Jan 18, 2004 11:45 AM
brega3
Jun 30, 2003 03:43 PM
1EK1EG
Jun 13, 2003 05:13 PM
