tial bov not sounding right
official honda whore
well ive been listening to the tial 50mm bov i have and it just doesnt sound right, im running the stock spring in it and im idling at around 15-17 and at 21-22 when decelerating, is this the problem, im running .6 bar spring and it sounds nothin like the clips ive heard, sounds more like a rattle snake or something
right now im only running 8lbs, but plan to step it up to 1 bar as soon as i get my 3 bar wired in
brian
Modified by coptzer at 7:24 PM 7/25/2005
brian
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">what sort of boost levels are you running.
and its not psi. vacuum is mm/hg
edited, thanks, jus typed it quick, and i also edited how much boost im running and planning on running, also does it matter if the bov is open at idle or not, im gonna run outside n check right now if it is or isnt
</TD></TR></TABLE>edited, thanks, jus typed it quick, and i also edited how much boost im running and planning on running, also does it matter if the bov is open at idle or not, im gonna run outside n check right now if it is or isnt
Who is Mr Robot?
well, the spring in the bov is a 9 psi spring. you are running only 8psi. what you are hearing is pretty much compressor surge. and its normal for most piston type bov's to be open at idle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">replied and problem solved i hope</TD></TR></TABLE>
yep just going to turn up the boost and deal with surge at low boost shifts
boosted_dc2
Dec 17, 2003 09:32 PM
DIRep972
Nov 23, 2001 05:17 PM
