EG JDM headlight install problem
Old Jul 14, 2005 | 11:31 AM
lushy77's Avatar
Default EG JDM headlight install problem
i wired up the headlights for my car. they worked fine. so i came on H-T did a search to find out how to get the city lights wired up. found what i needed. tried it. it worked for a minute then eveything stoppped working, except my highbeams.they work fine.
now i have no signal lights, or tail lights, nothing except for my highbeams.
i've tried everything i can think of.
anyone else have any ideas??? or have had a similar problem with this install????
any info would be greatly appreciated. i need to get to work tonite..lol
Old Jul 14, 2005 | 11:34 AM
neutron91's Avatar
Default Re: EG JDM headlight install problem (lushy77)
check your fuses and double check your work
Old Jul 14, 2005 | 11:38 AM
lushy77's Avatar
Default Re: EG JDM headlight install problem (neutron91)
i've triple checked my work. all looks good. i have no dash lights either. hmmmm
i have no extra fuses for my lights kicking around. i have all the others but no light fuses
Old Jul 14, 2005 | 11:48 AM
fakemike's Avatar
Even most gas stations sell fuses. It sounds like a blown fuse to me. Did you check the fuses?
Old Jul 14, 2005 | 12:38 PM
A.E Motoring's Avatar
Default Re: EG JDM headlight install problem (fakemike)
ppl usually just wire the city lights to the parking lights
Old Jul 15, 2005 | 02:21 AM
lushy77's Avatar
Default Re: EG JDM headlight install problem (SPNFEDEJ)
well, i figured out part of the problem. changed a few fuses for the headlights etc..
now the only problem is my signal will blink when i turn them on. but they don't come on when i turn my lights on.
there's a black green and red wire for the corner lights. but the red wire is the one that doesn't have a connection to it. should that be wired up??
thanks for the help guys. appreciate it.
Old Jul 15, 2005 | 02:55 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Did you do any research before you started doing this? Sounds to me like you screwed up your wiring... or just plain guessed.
Old Jul 15, 2005 | 03:31 AM
SnowSurfer's Avatar
the black wire is negative, red wire is positive, green wire makes your turn signals blink (a pulse wire so to speak)
when you wired the city lights did you wire black to black and red to red with out touching the green on the turn signal?
Old Jul 15, 2005 | 09:15 AM
lushy77's Avatar
Default Re: EG JDM headlight install problem (SnowSurfer)
okay heres the deal. the harness on the back of the signal light only has two wires. black and green. there is no red wire to connect the red wire coming from the car.
and yes i went black to black and red to red when i wired the city lights.
but what i don't get is why there is no red wire on the back of the harness on the corner light??? i'm stumped.
Old Jul 15, 2005 | 02:46 PM
SnowSurfer's Avatar
there is no red wire on both of them? thats really freaking wierd...did everything work before you took the headlights off?
Old Jul 15, 2005 | 02:47 PM
SnowSurfer's Avatar
would you be able to take a picture of the corner light harness
Old Jul 17, 2005 | 05:20 PM
lushy77's Avatar
yup. no red wire in the JDM corner light harness.
don't know what else to do really.
sorry for the late reply. was out of town all weekend. i'll see if i can get pics tomorrow.
thanks dude
Draiga1988
Jan 4, 2012 03:33 PM
skimeast1982
Audio / Security / Video
Oct 22, 2005 11:33 AM
dturbo
Mar 22, 2005 02:57 PM
NiceDc2r
May 13, 2004 09:42 PM
bo0sted
Oct 18, 2003 02:30 PM
