Lighting Problem!!!
Old Oct 17, 2003 | 07:57 PM
bo0sted's Avatar
Default Lighting Problem!!!
Ok well im at work tonight and right when i was leaving i turned my headlights on, my gauges didnt light up.......so i'm like hmm and i check the fuses and the fuse popped for interior lights. So i put a new one in turned the lights on again and my gauges didnt turn on. I checked the fuse again and it was still good????
Then by the time i get to my friends house he saw me pull up and he was like you know your corner lights and tail lights arent on? I was like no what the hell. So i check the tail light fuse and its good. I changed it out anyways just to make sure but they still wont light up. My break lights and turning lights do work though.
Any suggestions???? I need to fix this ASAP.
Old Oct 17, 2003 | 09:45 PM
bo0sted's Avatar
Default Re: Lighting Problem!!! (MwGSR)
Old Oct 18, 2003 | 02:22 AM
thaiphob's Avatar
Nikon!!!
did someone screw with your dimmer switch on your dash?
Old Oct 18, 2003 | 11:04 AM
GSRdriver's Avatar
Default Re: Lighting Problem!!! (thaiphob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">did someone screw with your dimmer switch on your dash?</TD></TR></TABLE>
I don't think that has anything to do with you tail lights and corner lights. Just your guages. I guess it couldn't hurt to check the dimmer ****.
You changed the fuses already? Electrical problem somewhere?
Old Oct 18, 2003 | 01:37 PM
jdmintegra1994's Avatar
Default Re: Lighting Problem!!! (GSRdriver)
i had thsi problem a week ago. it's a short circuit. Only other possibility (especially if the fuse is still ok) is the realy's gone bad and you have to replace it.
Old Oct 18, 2003 | 02:30 PM
bo0sted's Avatar
Default Re: Lighting Problem!!! (jdmintegra1994)
I found the problem it was a fuse under the hood called "+ something" forgot the exact name but i know it started with a +. I was really suprised that fuse would cause the lights to go out. thanks.
Juan Becerril
Classic Hondas
May 27, 2011 01:37 PM
JDMFEVER
Jun 27, 2008 04:43 PM
Orison21
Feb 21, 2004 03:28 PM
Mr Boston
Aug 7, 2002 08:22 PM
