horrible boggin
Old Jun 17, 2005 | 01:24 PM
Guru Designs's Avatar
* B A N N E D *
Default Horrible boggin
just put together my gsr and im getting a horrible boggin when i accelerate. its to the point that if i give it 100% throttle is will **** off. the only cel code im getting is air intake temperature. i did some troubleshooting with my snap on scanner and i think i have a problem with the wiring because if i disconnect the iat sensor the car should read a -42*f and if i jump the plug i should get a reading of 320*f but i only get a reading of 110*f which is the same reading i get if i connect the iat sensor. i checked all my ground and did a continuity test in the wire back to the computer. i have no clue what to do next. thanks in advance for your help.
Old Jun 18, 2005 | 07:48 AM
* B A N N E D *
no clues eh
Old Jun 18, 2005 | 11:12 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
i'd start by checking your timing
Old Jun 18, 2005 | 11:16 AM
* B A N N E D *
checked the timing and everything is on point. the car sat all winter and no one messed with anything. there is no way possible for a car to loose its timing while sitting. thanks though.
Old Jun 18, 2005 | 11:28 AM
you'd be suprised what can happen when a car sits for a long time
jvk
13
Jan 15, 2010 08:18 PM
TMTNG9
Aug 14, 2005 05:21 PM
AndyD
Aug 4, 2005 06:40 PM
Supahatch
Jul 5, 2005 01:35 PM
type Gendy
Mar 19, 2003 11:11 AM
