Is a P28 ecu compatible with a vx swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 »</TD></TR><TR><TD CLASS="quote">If I am not mistaken, the VX is a D15Z1 which is 5wire oxygen sensor. P28 runs off 4wire....so you have to convert</TD></TR></TABLE>
not all of the VX's used 5 wires, so it COULD work, depending on this..
The vx uses a wideband o2 sensor that is why it is a 5 wire. In fact i think my vx had a 7 wire sensor. You can rewire it to make it work, i am pretty sure you will have issues if you just connect it and go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katoeh2o »</TD></TR><TR><TD CLASS="quote"> The vx uses a wideband o2 sensor that is why it is a 5 wire. In fact i think my vx had a 7 wire sensor. You can rewire it to make it work, i am pretty sure you will have issues if you just connect it and go. </TD></TR></TABLE>
No, it did NOT use a 7 wire. I will put money on that.
They don't ALL use the 5 wire O2's. I have personally seen ones, stock, with 4 wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
not all of the VX's used 5 wires, so it COULD work, depending on this.. </TD></TR></TABLE>
If I remember correctly, CA had a 4-wire for VX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katoeh2o »</TD></TR><TR><TD CLASS="quote"> In fact i think my vx had a 7 wire sensor. </TD></TR></TABLE>
You are crazy.
A wideband 02 it 2 02 sensors in one. It has a non-heater (1-wire) and a heated (4-wire) so it is a 5 wire.
You are crazy.
I've heard of a P28 being used on a VX motor (user Built B16A used a chipped P28 with uberdata on his turbo VX).
BUT I would never use a stock P28 on a VX because:
1. P28 is designed for 240cc injectors, VX has 180cc...you risk running lean and blowing the motor up
2. The VX motor has a VERY LOW VTEC engagement point (when it switches over to 4 valve mode) and you'd have no power to 5,000 if you ran a P28.
3. The VX has an EGR valve to recirculate exhaust gas, i'm not sure if its operated by the ECU or not.
4. P28 is 4 wire, most VX's are 5 wire 02 and it wouldn't work anyway
Bottom line, get the right ECU for the motor (P07).
They don't ALL use the 5 wire O2's. I have personally seen ones, stock, with 4 wires.</TD></TR></TABLE>
He is talking about the engine harness side. Both the VX 5wire and my Y5 5wire actually have 7wires on the harness side but 5 on the sensor side
He is talking about the engine harness side. Both the VX 5wire and my Y5 5wire actually have 7wires on the harness side but 5 on the sensor side</TD></TR></TABLE>
I know what they have. I use a VX wideband to tune with. They might have 7 SPOTS for wires, but they do NOT have seven wires on either the sensor or the harness side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
3. The VX has an EGR valve to recirculate exhaust gas, i'm not sure if its operated by the ECU or not.</TD></TR></TABLE>
It is controlled by the ECU.
If the poster wants to pass smog, he will get the p07
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">
If the poster wants to pass smog, he will get the p07</TD></TR></TABLE>
I just happen to have one here for sale if anyone wants it. Same board as a P28 and yes, its chipped. You can easily cut the jumper and get it to run like "stock" if need be. Or I can do a custom VX program..whatever floats your boat.
Mentat Ghola
Oct 22, 2004 04:11 PM
