Turbo SOHC set up?
hey guys i just picked up a d16z6. Im still deciding on wat set up i should go with. i want it to be daily driven but have good hp. any advise??
Im planing on
Head:
fully port and polish
crower or skunk 2 complete valvetrain
stock cams
Block
9 to 1 comp prolly (je, wiesco, or srp pistons at .05mm overbore)
Rs Sleeve
eagle rods
Turbo kit
prolly a T3
So help me out guys, give me some advice on what to use.
I want to be runing like 10lbs daily and up to 15 lbs at the track for fun.
Im planing on
Head:
stock cams
Block
Rs Sleeve
eagle rods
Turbo kit
prolly a T3
i think this is the 2nd post in 2 days where someone has this great idea of dropping a ton of cash on sleeves and forged goodies and doesn't even mention fuel management.
yes, this is a statement and a suggestion. Now go read up on the current rom editors if your feeling brave...
Yes...you have the right idea for building your motor, but dont forget fuel management.
Try hondata or ubderdata.
If you're going to go that far with the head..might as well throw in a more aggressive camshaft.
Don't forget about keeping everything cool, such as your radiator. You might want to upgrade that too. At least get a dual core radiator from the dohc vtec delsols.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">you are upgrading your valvetrain, but keeping the stock camshaft
and don't forget engine management.
uberdata > hondata
and you only have one cam
</TD></TR></TABLE>and don't forget engine management.
uberdata > hondata
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic »</TD></TR><TR><TD CLASS="quote">and don't forget engine management.
uberdata > hondata
for sure
uberdata > hondata
</TD></TR></TABLE>for sure
You should swap to DOHC and get an intake, headerz, a big fart can, roll cage, racing seats, those Z3 fenders, and a huge tach... then your car would be really fast.
Seriously though, keep your motor stock and tune it well to about 200whp. Oh and do some research.
Head:
fully port and polish - not necessary
crower or skunk 2 complete valvetrain - not necessary
stock cams
Block
Rs Sleeve - not necessary
eagle rods
Turbo kit
prolly a T3 - go with a T3/T4 with a .48 exhaust wheel.
stock cams
Block
eagle rods
Turbo kit
thanks for the imput guys, oh my bad i totally forgot to put in the fuel managment up grade. i was giong to upgrade the injectors, and tuned by uberdata. oh and the cams was a mispelling lol. And for the stock cams, well my buddy who builds turbo sohc taht runs high 10s ran stock cams with. he bacally had the same set up i want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blindsk8er1013 »</TD></TR><TR><TD CLASS="quote">And for the stock cams, well my buddy who builds turbo sohc taht runs high 10s ran stock cams with. he bacally had the same set up i want.</TD></TR></TABLE>
What's the point of building the head up so you can rev higher, but not have a cam that will make more power at those higher rpms?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">
What's the point of building the head up so you can rev higher, but not have a cam that will make more power at those higher rpms?</TD></TR></TABLE>
why ask why man.........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blindsk8er1013 »</TD></TR><TR><TD CLASS="quote">thanks for the imput guys, oh my bad i totally forgot to put in the fuel managment up grade. i was giong to upgrade the injectors, and tuned by uberdata. oh and the cams was a mispelling lol. And for the stock cams, well my buddy who builds turbo sohc taht runs high 10s ran stock cams with. he bacally had the same set up i want.</TD></TR></TABLE>
People have gone 10's on LS motors without VTEC, doesn't mean it's a better choice than running a VTEC head. Bigger cam is definitely worthwhile.
My new setup made power out till 7800 redline where I stopped with a stock cam and upgraded valvetrain, I'm sure if i decided to go further, power would have kept climbing. Don't be so quick to jump down some guys throat because he's is asking questions that you don't have the answer too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool »</TD></TR><TR><TD CLASS="quote">My new setup made power out till 7800 redline where I stopped with a stock cam and upgraded valvetrain, I'm sure if i decided to go further, power would have kept climbing. Don't be so quick to jump down some guys throat because he's is asking questions that you don't have the answer too.</TD></TR></TABLE>
You made power all the way to 7800 rpms with a stock Z6 cam? You must have had some headwork done... maybe some boost creep?
Anyways, this guy's questions were way too broad to answer everything. It really sounds like this guy just needs to do a little research first. Although he has a buddy that runs high 10's with a SOHC and stock cam, so why not just ask him...
Modified by beerbongskickass at 6:23 AM 5/31/2005
Mopedstud
12
Dec 11, 2010 05:21 PM
