head studs
Old May 21, 2005 | 08:43 AM
kabaroo's Avatar
Default head studs
im putting my head studs in the block. ARP says to hand tighten them and when i do that they all go in at different depths. some only go in a few turns while some bottom out.
Does this matter? should i hand tighten them like this and then bolt everything down? or should i use an allen wrench to bottom out all the head studs?
Old May 21, 2005 | 08:53 AM
kabaroo's Avatar
Default Re: head studs (kabaroo)
please, someone so i can go back out to the garage.
Old May 21, 2005 | 08:55 AM
_BEN_'s Avatar
Chase the threads with a tap to clean them.
Old May 21, 2005 | 08:57 AM
kabaroo's Avatar
Default Re: head studs (_BEN_)
arg, i dont have a tap!
Old May 21, 2005 | 08:59 AM
Hatchamaback's Avatar
a guy at speedway motors told me to torque them down to about 15 ft 1bs of torque. I havnt done it to my B18 yet. Call ARP and do a bigger search here on HT.
Old May 21, 2005 | 09:03 AM
_BEN_'s Avatar
You could use a stiff bristed bottle brush if you don't have a tap.
Old May 21, 2005 | 09:20 AM
kabaroo's Avatar
ill look around and see what i can find. thanks guys.
Old May 21, 2005 | 09:48 AM
kabaroo's Avatar
good news... i got 3 down,
Old May 21, 2005 | 09:54 AM
_BEN_'s Avatar
You could also try jamming two nuts together and turning the studs in with a wrench.
Old May 21, 2005 | 09:58 AM
kabaroo's Avatar
i know, i would have done that, but it tells you to hand tighten them?
Do you think it would matter?
Im guessing they just dont want you to tighten too far into the block.
Old May 21, 2005 | 10:41 AM
Methuselah's Avatar
Yea, that's after you know the threads are clean. The studs should all be the same height, don't do a half-assed install. A tap at sears or autozone will cost $10.
black0hatch
Honda CR-V & Element
Aug 30, 2012 01:29 PM
phelpsj2
Feb 13, 2012 03:26 PM
hYbRid_Eg6
Jan 26, 2012 10:00 PM
horn12007
19
Sep 20, 2010 06:02 PM
flip1199
Aug 2, 2005 12:28 PM
