REAL High-flow cat
Old May 20, 2005 | 11:39 AM
Lewdin' Incognito's Avatar
Default REAL High-flow cat
I'm looking for a high-flow cat for my '92 H23 vtec. All I can find are testpipes, but I have to be able to pass emissions. I want to do it right, interested more in quality than the cheapest I can get; within reason of course.
-I've been searching, but keep getting error that the search server is down.
TIA
Old May 21, 2005 | 12:16 AM
Default Re: REAL High-flow cat (Lewdin' Incognito)
Old May 21, 2005 | 12:37 AM
no2unenolife's Avatar
check kteller.com
Old May 21, 2005 | 03:54 AM
.water's Avatar
SMSP h-t sn for custom length..yes kteller is also good.
Old May 21, 2005 | 10:15 AM
Deluzional's Avatar
Default Re: REAL High-flow cat (Chris DC2)
Honestly, a high flow cat will not pass smog. I have not had any experienve with smsp cats, but carsound claims to be 50 state legal(lie)
Old May 21, 2005 | 07:27 PM
zacdaddy77's Avatar
Default Re: REAL High-flow cat (Deluzional)
why don't you put on a stock cat for the test? then swap out?
Old May 21, 2005 | 07:29 PM
_gurusan_'s Avatar
Default Re: REAL High-flow cat (zacdaddy77)
You can't pass with carsound cat????
Anyway I have an OEM 93 civic ex cat .....100k miles on it...functioned fine...swapped it out for a 2.25'' carsound....
I'll sell it for 25+ shipping
Old May 21, 2005 | 08:18 PM
Deluzional's Avatar
Default Re: REAL High-flow cat (_gurusan_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ &raquo;</TD></TR><TR><TD CLASS="quote">You can't pass with carsound cat????
nope, failed smog with it, so did 2 of my other friends.
EDIT: this is coming from boosted cars tho
Old Jun 8, 2005 | 12:15 PM
integraXTC's Avatar
where are you located
Old Jun 8, 2005 | 05:54 PM
slomofo's Avatar
GDD Member
All cats are the same, test pipes aren't cats. Legal Hi-Flow cats are just normal cats with an upped price that say "High flow" on them. Illegal hi-flow cats are pipes made to resemble cats. Trust me dude, I've been a safety/emissions (smog) tester for five years.
Old Jun 8, 2005 | 10:35 PM
h2392si's Avatar
Default Re: (slomofo)
get a magnaflow/carsound cat. Yes you can pass with one, i have in smog capital california. Peace.
Old Jul 27, 2005 | 01:00 PM
the_23rd_letter's Avatar
Default Re: (h2392si)
i know this is a month late post but i thought this was pretty interesting when i read it. Ill probably get flamed for this but... i was reading the latest issue of modified magazine *gasp* and stumbled across their "The Real JDM" column for the month which just so happened to focus on "green power" and primarily hitting on high flow cats and quiter exhausts.
Apparently some of the fastest time attack cars such as the Autech Tsukada BNR34 GT-R and Top Secrets V35 widebody Skyline coupe are completely street legal. The Autech GT-R for example produces 0 Hydro carbon parts per million and has 0% carbon monoxide rating. Unfortunately the cats they are using utilize platinum to extract the most power per hydrocarbon and platinum isn't exactly cheap. Also noted is that the APEX super catalyzer is "one of the leaders" in the japanese market. It uses 130 cells per square inch as compared to a stock cat which will use somewhere between 400-600 c/si and this lower number of cells supposedly improves exhaust flow resulting in an increase in power.
Now what id really like to know is what aspects of a cat cause low HC ppm and CO% numbers. hope this helps someone in some way
ohhhmarkymarkEG6
Jul 18, 2006 09:23 PM
GsR-Freak
Apr 3, 2005 11:40 PM
ekb16
Mar 1, 2005 09:06 PM
Canuk_SiR
Oct 30, 2003 08:50 AM
Thrillhouse
Jul 22, 2003 07:55 AM
