compression test
Old Feb 5, 2002 | 05:34 PM
93sircivic's Avatar
Default compression test
What psi range should my engine read, so that I know that it is in good condition? engine is a 97 b18c5 stock everything
Thanks
Old Feb 5, 2002 | 06:34 PM
IntegD's Avatar
New User
Default Re: compression test (93sircivic)
Around 210-225i s h think that is what they should be...maybe a little higher
[Modified by IntegD, 7:34 PM 2/5/2002]
Old Feb 5, 2002 | 06:45 PM
nfn15037's Avatar
Default Re: compression test (IntegD)
Probably a lil higher, as i just did my GSR and it was 210 across the board.
Old Feb 5, 2002 | 07:51 PM
Mr Hammond's Avatar
a/k/a Jomo
The JDM spec H22A we swapped into an accord read 235 across all 4. We did a B16A2 that read 190 across all 4...little on the low side?...what does everyone think of this number for the B?
thanks.
Old Feb 5, 2002 | 08:17 PM
Pinhead's Avatar
New User
Default Re: compression test (Mr Milano)
I ran 235's plus of minus 5 down the line
Old Feb 5, 2002 | 08:51 PM
93sircivic's Avatar
I have one of those crappy push in type testers, and got 205 on 3 of them and 200 on 1 of them.
Interesting.......and I did follow the directions on how to do the test, will check again with oil tomarrow, and maybe get a better tester
Old Feb 6, 2002 | 06:00 AM
iperez's Avatar
My 2001 ITR with a Spoon 2-ply head gasket is reading 235 across the board. I thought it would be higher. I didn't read the compression before the gasket my bad ... How much compression is expected with CTR pistons ?? What about oversized CTR pistons ?? Anybody know ??
Old Feb 6, 2002 | 06:08 AM
Johnny Tran's Avatar
Default Re: compression test (iperez)
my crappy b16 read 275-280 all across........but its got a couple things
the key is to have consistent readings....no more than 10-15% variance across . good luck
Old Feb 6, 2002 | 07:11 AM
BABY NSX's Avatar
Default Re: compression test (Johnny Tran)
The design of tester itself can play a large factor in what the actual readings are. Just make sure the readings are close to each other as has already been stated!
Anywhere from 200 to 230 seems to be the range that most people are getting.
Old Feb 6, 2002 | 07:51 PM
93sircivic's Avatar
I bought a new screw in type tester and the readings went up significantly.
about 235-240 ish all across.
Thanks
Boostn B20
11
Nov 27, 2008 01:22 PM
Keeper1343
Dec 17, 2007 09:10 PM
BLK99VTECR
Dec 25, 2005 09:27 PM
Hondizzle!
Sep 13, 2005 09:13 AM
Convoy
Feb 28, 2003 04:54 PM
