d16y8 and turbo question
Old May 18, 2005 | 01:54 PM
ej7d16y5's Avatar
Default d16y8 and turbo question
i have a d16y5 with 130k miles on it. im planning on getting a d16y8 head and then getting some boost this summer....would it be safe??? or would i have to build up my block?
Old May 18, 2005 | 02:01 PM
flood's Avatar
Default Re: d16y8 and turbo question (ej7d16y5)
Honda blocks weren't made with boost in mind. You can run a bit o' boost and be ok, but the cylinder walls flex. Thats a bad thing. ECU freaks when you get boost too.
You will get this 1million times, its all in the tune. Upgrade your ECU to compensate for boost and keep it low (less than 8) and you would most likely not run into too many problems. With everything in life, to do it right requries time/money/effort and knowlege.
Of course there will be replies about how their stock block has taken 10psi and 7k rpms every day for the last 7 1/2 years with 300,000mi on it and it runs better than when it was brand new.
OH and this belongs in the FI section
Old May 18, 2005 | 02:51 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej7d16y5 &raquo;</TD></TR><TR><TD CLASS="quote">i have a d16y5 with 130k miles on it. im planning on getting a d16y8 head and then getting some boost this summer....would it be safe??? or would i have to build up my block?
Keep the Y5 head and boost
Old May 18, 2005 | 03:05 PM
EJ1 wilcox's Avatar
Default Re: d16y8 and turbo question (specv5150)
Research research research.... read read read.... learn learn learn....
This question has been asked hundreds of times.
You will be able to answer your own question if you take some time to learn a bit.
You don't have to build your block to boost it... depending on the amount of boost.
Old May 18, 2005 | 06:33 PM
ej7d16y5's Avatar
alright....thanks
Old May 18, 2005 | 06:38 PM
BauleyCivic's Avatar
Risky Business
Default Re: (ej7d16y5)
The Y5/Y8 swap is fairly difficult, as there is a lot of **** involved. Personally I would just do a straight Y8 swap.
Old May 19, 2005 | 03:34 AM
specv5150's Avatar
Default Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">The Y5/Y8 swap is fairly difficult, as there is a lot of **** involved. Personally I would just do a straight Y8 swap.</TD></TR></TABLE>
I am a little curious. I don't plan on swapping but I was had before. What makes it so difficult?
Old May 19, 2005 | 04:38 AM
jolt-tsp's Avatar
Default Re: (specv5150)
I know it's not what you asked, but whats wrong with the y5? IMO the y8 doesn't have near enough advantages to swap.
Old May 19, 2005 | 01:54 PM
specv5150's Avatar
Default Re: (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">I know it's not what you asked, but whats wrong with the y5? IMO the y8 doesn't have near enough advantages to swap.</TD></TR></TABLE>
I wondered the same thing. The only thing I can think of is 13hp that the Y8 offers and maybe the mileage....the Y5 is quite the engine with boost. I can't wait to get mine boosted again..one more week
Old May 20, 2005 | 04:37 AM
jolt-tsp's Avatar
One more week here too. T25 in the mail. Old one blew. With a crappy t25 setup on my y5 I was able to hold up in a straightline against an s2k. That was untuned with no intercooler though, will probably be able to pull a bit after tuning and now that I have my IC. Plus I can outhandle the s2k easily :-D
So to the original poster, I say keep the y5.
mrperformance
May 17, 2012 03:03 PM
lileghatch
Mar 24, 2009 03:09 PM
sladed16y8
Jan 22, 2007 07:19 PM
00BoostedD16
Nov 9, 2004 09:39 AM
Civic2Fast
Nov 9, 2003 03:25 PM
