Question about part URGENT
Old May 17, 2005 | 06:18 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Question about part URGENT
Whats that thing that bolts onto the tranny and moves the shift fork back and forth?
Mine broke and popped off
Old May 17, 2005 | 06:37 PM
Kyles ej1's Avatar
Default Re: Question about part URGENT (MugenHonda)
um...
Old May 17, 2005 | 06:42 PM
MugenHonda's Avatar
Default Re: Question about part URGENT (93ejay1)
PLEASE
Old May 17, 2005 | 06:46 PM
Archidictus's Avatar
Unceasing Measure
The shift linkage? **** if I know. Your description sucks hardcore. Find a schematic and circle that **** in MS paint if you want us to help you. Goddamn, is this nursery school or what?
Old May 17, 2005 | 06:48 PM
Kyles ej1's Avatar
Default Re: Question about part URGENT (Archidictus)
yea thats what i said then i edited it cuz it doesnt connect the tranny to the shift fork
Old May 17, 2005 | 06:54 PM
MugenHonda's Avatar
how does my description suck, I can't explain it any better.
There is ONLY one thing that moves the shift fork on a hydrop tranny, and that is connected to the slave cylinder by a hose
Old May 18, 2005 | 04:13 AM
EE_Chris's Avatar
WTF are you talking about?
For a second, I thought you were talking about the bitch pin maybe, but now you're mentioning the slave cylinder.
Shift forks are INSIDE the transmission. The shift linkage connects to the shift rod (via the bitch pin) and the shift rod move the shifter forks.
The master cylinder actuates the slave cylinder - the slave cylinder pushes on the clutch release fork - the clutch release fork is holding the throwout bearing which pushes against the pressure plate.
It almost sounds like you're talking about the actuator rod which is part of the slave cylinder assembly - that is the thing that physically pushes against the clutch release fork.
Old May 18, 2005 | 06:13 AM
snatch's Avatar
Default Re: Question about part URGENT (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">WTF are you talking about?
It almost sounds like you're talking about the actuator rod which is part of the slave cylinder assembly - that is the thing that physically pushes against the clutch release fork.</TD></TR></TABLE>
This is all there is man. The slave cylinder part threw me off too. Go to http://www.hondaautomotiveparts.com, find the part, circle that bitch and come back here.
htwannabi
Nov 1, 2008 07:45 PM
hollot1p
Aug 21, 2006 10:46 PM
mike1114
Jul 11, 2004 12:54 AM
mike1114
Jul 10, 2004 06:37 PM
Mr.DC2TurBo
Mar 17, 2003 09:57 AM
