Shifting issues PLEASE HELP!!!!!!!!
Old Jul 10, 2004 | 01:03 PM
mike1114's Avatar
Default Shifting issues PLEASE HELP!!!!!!!!
I posted this up a few months ago and still couldn't get to the bottom of whats wrong with my car.
Here's the story:
After like about a half hour of driving, my clutch seems to loose pressue and not be able to shift anymore. Once I let the car sit and cool down for a few hours it will drive like butter again, but after some time driving it feels like the gears start to get sticky and then eventually I cannot shift, It feels like I'm trying to shift without pushing in the clutch.
At first your all going to think, slave cylinder or master cylinder. I replaced them and things get even worse now I cannot shift at all. IF I put back in the old master cylinder that was originally in there I can shift again but after driving for a while it will get hard to shift again.
I've tried 3 different master cylinders and two slaves, all brand new with no success. I even tried making a heat shield for the slave cylinder as I thought the turbo was making the slave too hot but not luck.
Motor is 95 GSR with T3/T4 turbo setup, log mani.
Anyone have any advice?
Old Jul 10, 2004 | 03:23 PM
RACETUNE1's Avatar
Default Re: Shifting issues PLEASE HELP!!!!!!!! (mike1114)
what clutch disc u are using?
what pressure plate are u using?
what flywheel are u using?
let me know detail on your drivetrain setup, try to see if can be diagnosed, with out being there.
Old Jul 10, 2004 | 05:50 PM
mike1114's Avatar
Default Re: Shifting issues PLEASE HELP!!!!!!!! (RACETUNE1)
ACT XTSS, Fidanza 8.5lb flywheel.
Old Jul 11, 2004 | 12:54 AM
honda_power69's Avatar
This might be a dumb question...as I'm not too familiar with your posts on this board...but you did bleed the system after those installs right?
MiKeEH
Nov 11, 2009 12:54 AM
hookedonponics
Nov 15, 2007 04:08 PM
GSRWSU
Oct 22, 2006 11:03 AM
mike1114
Jul 10, 2004 06:37 PM
del_parker
Sep 1, 2003 07:17 PM
