Longer Rod = slower acc. at TDC, but...slower or quicker at BDC?
Old May 16, 2005 | 09:48 AM
kevinoneill's Avatar
Default Longer Rod = slower acc. at TDC, but...slower or quicker at BDC?
I was reading an artcile from grapeaperacing.com Connecting Rods
He talks about piston acceleration and labels as a pro for longer connecting rods that it will slow peak piston acc. going towards and away from TDC.
What Id like to know is if acc. decreases at TDC, does that reflect it acc. faster at BDC? and if so, is that good, bad, or indifferent.
Shorter rods have a higher acc. at TDC...again what at BDC?
ps. Im in a Roma right now! So might be a day or 2 until i get back to this post, im paying for internet access...
keep it alive for me! dont mind wandering of topic a little if its good discussion.
Old May 16, 2005 | 10:32 AM
_BEN_'s Avatar
Default Re: Longer Rod = slower acc. at TDC, but...slower or quicker at BDC? (kevinoneill)
TDC and BDC speeds will be the same.
It would be impossible for them to be different unless the crank shaft is flexable or the rods stretch and compress like rubber.
Here is another post talking about this. There is also a couple diagrams that show the speed.
https://honda-tech.com/zero...age=1
Old May 18, 2005 | 06:46 AM
Default Re: Longer Rod = slower acc. at TDC, but...slower or quicker at BDC? (_BEN_)
Ah good read, ill have to wait til i get home to read all of it though, thanks.
Old May 18, 2005 | 08:27 AM
JimBlake's Avatar
TDC speed = BDC speed = zero.
Exactly at TDC & BDC the piston reverses & speed is momentarily zero.
Acceleration at TDC is larger than acceleration at BDC. As the rod gets longer they get more equal to each other.
With an infinitely long rod, the maximum piston speed is exactly at mid-stroke. As the rod gets shorter, the max speed is larger & the position it occurs is higher up in the cylinder.
Old May 18, 2005 | 09:23 AM
Dogginator's Avatar
Daisy... Daisy...
Yet another recent link.
https://honda-tech.com/zerothread?id=1245052
Old May 19, 2005 | 01:56 AM
Default Re: Longer Rod = slower acc. at TDC, but...slower or quicker at BDC? (Dogginator)
Hey thanks, yeah being in rome i have to pay for internet access...soo....not much time to search archives! i just had to know right now
Old May 19, 2005 | 04:10 PM
StorminMatt's Avatar
Actually, if you do the math and look things over, you will see that a longer rod leads to increased piston deceleration at BDC! Piston movement can be considered to be quasi-sinusoidal. In other words, it moves in a kind of sine wave, but not exactly. However, as the rod length increases, the piston motion becomes more and more sinusoidal. And sinusoidal motion means that acceleration at TDC is numerically equal to acceleration at BDC. With a finite length rod, acceleration is faster at TDC and slower at BDC compared to sinusoidal. But as rod length decreases, acceleration decreases at TDC and increases at BDC as the accelerations become more equal. This might seem to make a bad case for a longer rod. But not really. Although BDC acceleration icreases with a longer rod, the MAXIMUM acceleration experienced by the piston (which occurs at TDC with a finite length rod) actually decreases.
Old May 19, 2005 | 05:11 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Longer Rod = slower acc. at TDC, but...slower or quicker at BDC? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">But as rod length increases, acceleration decreases at TDC and increases at BDC as the accelerations become more equal.</TD></TR></TABLE>
Fixed it for you.
Please see my post here:
Old May 22, 2005 | 06:05 AM
That link was already given
Old May 22, 2005 | 06:10 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinoneill &raquo;</TD></TR><TR><TD CLASS="quote">That link was already given </TD></TR></TABLE>
I know.
Old Aug 6, 2005 | 08:07 PM
#1151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">TDC and BDC speeds will be the same.
</TD></TR></TABLE> lol
K2e2vin
Jun 12, 2006 01:10 PM
Speed Infliction
May 2, 2006 07:43 AM
johncarlos
May 1, 2004 02:51 AM
94CivSi
Apr 11, 2004 06:14 PM
soundman
Sep 3, 2003 05:40 AM
