Stock B16 turbo (Searched)
Old May 8, 2005 | 06:55 PM
meanB6teen's Avatar
Default Stock B16 turbo (Searched)
What kind of power did you see from your stock motor. Just want to wanna know what I'll expect to see when I get it tuned. I'll be using a t3/t4 57 trim.
Old May 8, 2005 | 07:31 PM
meanB6teen's Avatar
Default Re: Stock B16 turbo (meanB6teen)
any1
Old May 8, 2005 | 07:44 PM
stoopid_monkey's Avatar
im interested to find out also.
Old May 8, 2005 | 07:54 PM
kjohnl's Avatar
https://honda-tech.com/zerosearch
Old May 8, 2005 | 08:00 PM
DRIVENRacing's Avatar
210 whp @ 5 psi on a stock b16a2 and a t3t4 63 trim..
Old May 8, 2005 | 08:10 PM
nsxmatt's Avatar
249whp at 9psi old setup
est about 265-270 or so on the new setup at 10psi Same turbo your talking about on a stock B16.
Old May 8, 2005 | 08:11 PM
meanB6teen's Avatar
Default Re: (nsxmatt)
Can you tell me both set up's?
Old May 9, 2005 | 03:50 AM
nsxmatt's Avatar
Default Re: (meanB6teen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanB6teen &raquo;</TD></TR><TR><TD CLASS="quote">Can you tell me both set up's?</TD></TR></TABLE>
First was a drag kit w/fmu, stock injectors, ecu, ect.
New setup has a Neukin manifold, 3" downpipe, and wastegate, Hondata, and RC 750's on top of that.
Old May 9, 2005 | 06:28 AM
meanB6teen's Avatar
This will be my setup and i'll be using neptune:
t3/t4 57 trim
walboro 255
peakboost ic piping
tial WG and BOV
dsm 440's
bmc elf 3.0
3" downpipe
Hoping to see good numbers!
Old May 9, 2005 | 07:30 AM
raene's Avatar
See sig.
Old May 9, 2005 | 05:16 PM
meanB6teen's Avatar
Default Re: Stock B16 turbo (raene)
Thanks raene I hope to see good numbers like that.
Old May 9, 2005 | 05:23 PM
raene's Avatar
good luck, mine was done on open 3" downpipe on a Dyno Dynamics dyno so it probably reads a little higher than the Dynojet numbers. Should be about 250whp, which should be pretty comparable to what everyone gets with this turbo at that boost on a B16
Old May 9, 2005 | 05:25 PM
meanB6teen's Avatar
Im gonna be using a mustang dyno.
Old May 9, 2005 | 05:34 PM
markaria's Avatar
My first turbo set up was a stock jdm b16 block/ stock itr head with a 48/60 t3/t4 and hondata/rc550's I put down 217whp on a mustang dyno (payn) at 7psi. I do remember Tom saying he didnt think we would see over 200whp, and he was a bit surprised when we hit 201whp on the 1st pull (let off at 6800 rpm lol). Hope this helps
Old May 9, 2005 | 05:46 PM
meanB6teen's Avatar
Default Re: Stock B16 turbo (markaria)
Every little bit helps
Old May 10, 2005 | 07:03 PM
meanB6teen's Avatar
adSpeed what was your first setup
Old May 10, 2005 | 07:08 PM
...emu...'s Avatar
220 whp at 7psi
Drag gen 3 kit
t3/t4 turbonetics turbo
spearco fmic
rc engineering 440cc injectors
VAFC II
Tuned using the "hack" method... i highly recommend better engine management...
Old May 10, 2005 | 07:18 PM
meanB6teen's Avatar
Default Re: Stock B16 turbo (...boo$tedEM1...)
yea i'll be using neptune
Old May 10, 2005 | 07:22 PM
...emu...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanB6teen &raquo;</TD></TR><TR><TD CLASS="quote">yea i'll be using neptune</TD></TR></TABLE>
sweet.... thats what I'm saving for
Old May 10, 2005 | 07:25 PM
meanB6teen's Avatar
Well the place nearby that does it if they give an off the wall expensive price then im gonna go with hondata or aem ems
Old May 10, 2005 | 07:27 PM
DaveF's Avatar
320 (only reved to 8,000, prolly woulda made more if reved higher, like 8500/9000)
stock 1gen block. built head, crazy turbo.....
check here for more pics/info
Old May 10, 2005 | 07:30 PM
meanB6teen's Avatar
Default Re: Stock B16 turbo (Dturbocivic)
Those are some awesome *** number's. What was the turbo setup?
Old May 10, 2005 | 07:32 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanB6teen &raquo;</TD></TR><TR><TD CLASS="quote">Those are some awesome *** number's. What was the turbo setup?</TD></TR></TABLE>
manifold that we made
turbonetics ball bearing t66/ptrim/ .81 ex housing
3inch intercooler piping
precision "750hp" intercooler
3inch side exit downpipe
75mm holley tb
edelbrock intake mani.
tial 46mm wg.
greddy type-r bov.
Old May 10, 2005 | 07:56 PM
vw eater's Avatar
any pic's of the b16 turbos..?
red_hatchback
May 30, 2007 10:56 AM
Rhymenoceros
Aug 6, 2006 07:04 AM
crxnj
Dec 22, 2005 10:04 AM
AaronJ
Oct 13, 2005 11:51 AM
