D15B Swap
Old May 5, 2005 | 04:13 PM
b20vtechatch
Guest
Posts: n/a
Default NEED HELP D15B Swap
I swapped a D15B, everything is hooked up and ready to go, but when I turn the key the radiator fan turns on and nothing happens, the car won't start. What's going on?
Modified by b20vtechatch at 5:29 PM 5/5/2005
Old May 5, 2005 | 04:33 PM
b20vtechatch
Guest
Posts: n/a
Default Re: NEED HELP D15B Swap (b20vtechatch)
IVE DONE MANY SWAPS AND IVE NEVER SEEN THIS. I TURN THE KEY AND THE FAN TURNS ON NOTHING ELSE HAPPENS. DOESNT TURN OVER OR ANYTHING. HAS ANYONE EVER SEEN THIS.
Old May 5, 2005 | 04:36 PM
.Beaver's Avatar
Bloody Beaver
never heard of that happening before.... maybe miswired something
Old May 5, 2005 | 04:40 PM
b20vtechatch
Guest
Posts: n/a
Default Re: NEED HELP D15B Swap (Dr. Beaver)
MAN THIS SUX. ANYONE ELSE HELP ME OUT.
Old May 5, 2005 | 04:52 PM
civicboisi's Avatar
what type of vehicle is it going into? Anything else besides just the stock d15b? Check and recheck ur grounds...no clicks no crank means no ground half the time...
Old May 5, 2005 | 05:18 PM
b20vtechatch
Guest
Posts: n/a
Default Re: NEED HELP D15B Swap (civicboisi)
the tranny ground isnt hooked ill check that thanks, but anything else
Old May 5, 2005 | 05:22 PM
slotec's Avatar
push the clutch completely to the flood, like til theres no more space between the floor and the clutch. some peoples clutches do that, mine was one
Old May 5, 2005 | 06:09 PM
civicboisi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechatch &raquo;</TD></TR><TR><TD CLASS="quote">the tranny ground isnt hooked ill check that thanks, but anything else</TD></TR></TABLE>
hook it up!
Old May 5, 2005 | 06:51 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
check all your fuses.. when putting in the new swap, maybe you didn't disconect the battery, and shorted out a fuse.
Old May 5, 2005 | 08:07 PM
mike93eh
Guest
Posts: n/a
if the tranny ground isnt hooked up, it wont crank. along with the thermostat housing ground.
Old May 5, 2005 | 08:20 PM
Otherguy's Avatar
NASIOC.com
Default Re: (mike93eh)
lol that happend to me... hahahah
Old May 6, 2005 | 04:37 AM
b20vtechatch
Guest
Posts: n/a
Default Re: (Otherguy)
awsome guys it was the tranny ground. the thermostat one was already hooked up. im putting this jdm d15b for school a temporary motor. im going to UTI in mass. i had a turboed ls bottom end was fully built stock sleeves 16psi. sold that for 2,600 and and i started a frankenstien. sleeved shooting for 22psi.
Old May 8, 2005 | 06:58 PM
HULKHATCH10's Avatar
Default Re: (b20vtechatch)
U GOING TO THE NEW UTI IN NORWOOD?? HIT ME UP MIGHT BE SEEING YA THERE JUN 27. PCE
Old May 13, 2005 | 04:04 AM
b20vtechatch
Guest
Posts: n/a
Default Re: (HULKHATCH10)
yea i start in august
Old May 16, 2005 | 04:35 AM
Thrillhouse's Avatar
I went to UTI in cali, god what a waste of money hope yours is better
Old May 17, 2005 | 05:30 AM
b20vtechatch
Guest
Posts: n/a
Default Re: (Thrillhouse)
this is a brand new camps it should be awsume.
circapunk
Jun 19, 2009 10:54 AM
ChiDubysLS-VTEC
Apr 18, 2009 04:36 PM
LaOstha
Oct 26, 2006 05:51 PM
90Integra
Jun 29, 2005 12:39 PM
The Stance
14
Nov 23, 2004 08:40 PM
