D15B Swap
Re: NEED HELP D15B Swap (b20vtechatch)
what type of vehicle is it going into? Anything else besides just the stock d15b? Check and recheck ur grounds...no clicks no crank means no ground half the time...
push the clutch completely to the flood, like til theres no more space between the floor and the clutch. some peoples clutches do that, mine was one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechatch »</TD></TR><TR><TD CLASS="quote">the tranny ground isnt hooked ill check that thanks, but anything else</TD></TR></TABLE>
hook it up!
hook it up!
Location: hittin corners so hard you can taste my rims..
check all your fuses.. when putting in the new swap, maybe you didn't disconect the battery, and shorted out a fuse.
Guest
Posts: n/a
Re: (Otherguy)
awsome guys it was the tranny ground. the thermostat one was already hooked up. im putting this jdm d15b for school a temporary motor. im going to UTI in mass. i had a turboed ls bottom end was fully built stock sleeves 16psi. sold that for 2,600 and and i started a frankenstien. sleeved shooting for 22psi.
ChiDubysLS-VTEC
04-18-2009 04:36 PM
The Stance
14
11-23-2004 08:40 PM
