Would shortening the wastegate arm help boost from falling off at high rpms?
why would you think that it wouldnt work? Greddy 18g, b16a, trying to run 8 psi, drops down to 5-6 by 7200ish. i dont know why. no vac leaks. so i was going to try to shorten the wastegate actuator arm and hoping that would help out and hold boost longer in the rpm range. but maybe it wont
I have a similar problem running a small wrx turbo on my car. It drops from 10psi straight down to 8psi after vtec engages. There are definintly no vac leaks either. The weird thing is that I have an external tial 38mm wastegate rather than a hard to control internal gate
i know a bigger turbo will help, but then i'm going to have to get a new manifold, downpipe, get an egt bung put in the new downpipe, get 2 o2 bungs put in the new downpipe and then i have to get new oil lines and a new oil pan, and i will have to re route my ic piping most likely. so i'd like to make this turbo work for a while while its on the car. so i'm trying to find out why its not holding boost. other people can get it to hold 10psi till redline with no problems.
