bushings
Old Apr 28, 2005 | 09:06 PM
idriveadelsol7's Avatar
Default bushings
i purchased a gsr rear sway bar for my del sol... the bushing around the bracket connecting to the control arm looks broken apart. how long do bushings usually last for? what would happen if i do not replace it? thank you.
Old Apr 28, 2005 | 10:28 PM
Default Re: bushings (idriveadelsol7)
Old Apr 29, 2005 | 07:44 AM
Old Apr 29, 2005 | 07:47 AM
Redcoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">i purchased a gsr rear sway bar for my del sol... the bushing around the bracket connecting to the control arm looks broken apart. how long do bushings usually last for? what would happen if i do not replace it? thank you.</TD></TR></TABLE>Try energy suspension bushing kits. They do wonders. I am replacing all bushings now.
Old Apr 29, 2005 | 07:49 AM
Cuong-nutz's Avatar
just replace the bushings with some poly ones and you'll be fine. if you don't replace them, they'll eventually crack and you'll have loss in handling due to added looseness.
fasthatchb18c1's Avatar
It all depends on what kind of elements your car went through like salt and things of that nature. Its not that hard to repalce your bushings you could usr a tourch and burn them out and cut out the metal surrounding the bushing with a hack saw or take it to a shop that has a hydrolic press and get them pressed out. For new ones I would go with energy suspension and you can put them in your self. If you dont replace them and there worn out your car will handle like crap
Old Apr 29, 2005 | 08:25 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (fasthatchb18c1)
The hardest part to replacing bushings is getting your old ones out. Burning them takes forever and you'll be lucky if you can hammer them out. If yours are all busted up, you might be able to get them out. Pressing ES bushings in is really easy, you can do it with your hands.
Old Apr 29, 2005 | 08:36 AM
wilsel's Avatar
Default Re: (litterbox)
Those bushings are only a few bucks. Might as well replace them now. You car won't handle any worse than it does without the swaybar, but you don't want the swaybar bushings to fall out either.
Old Apr 29, 2005 | 10:16 AM
Default Re: (wilsel)
they're look broken ... but not to the point where i can just take them off. they're freaking stuck still. maybe they're still good. haha
Old Apr 29, 2005 | 01:20 PM
dohcdelsol93's Avatar
Default Re: (idriveadelsol7)
I used a hydrolic press to remove my bushings. Forget hammering them out. My car is from Michigan. The bushings were seized.
OmarR
Suspension & Brakes
Aug 25, 2013 05:30 PM
JC_1118
Jul 31, 2013 04:20 PM
ShinotakuX
Jul 20, 2009 06:06 PM
EG2Driver
Jul 27, 2006 10:14 PM
idriveadelsol7
Suspension & Brakes
Apr 29, 2005 10:16 AM
