fast turbo lines, tapping pan
I tried searching but couldnt find a direct answer...but i just ordered some fast turbo lines off somebody "new" but the directions seemed incomplete or started on step "10"
From what i could gather, it says drill the hole in oil pan and then the fitting is tightened with a nut?? Does it not require welding ???
Sorry if this has been covered before. but TIA
i know thats the conventional way of donig it, but the instructions state this:
-drill oil pan with 11/16" bit
-insert smaller fitting into oil pan, and secure the back with the black washer and nut, tighten with crescent wrench
