Installin a turbo on a ls need help!
Old Apr 19, 2005 | 06:48 AM
tony n.'s Avatar
Default Installin a turbo on a ls need help!
im installin a turbo on my friends hatchback this weekend he has a ls, its a drag kit, i was wonderin how do you retard the timing...and where would i get all my vacuum from? thx in advance!
Old Apr 19, 2005 | 07:48 AM
Evanmb44's Avatar
what are you using for engine management?
please dont tell me you are using the fmu
fmu=poopy
Old Apr 19, 2005 | 07:49 AM
Civicman86's Avatar
Default Re: Installin a turbo on a ls need help! (boosted2cam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted2cam &raquo;</TD></TR><TR><TD CLASS="quote">im installin a turbo on my friends hatchback this weekend he has a ls, its a drag kit, i was wonderin how do you retard the timing...and where would i get all my vacuum from? thx in advance!</TD></TR></TABLE>
Timing done either dizzy or via fuelmangment
I got my vac from the brake boost line on the firewall.
Old Apr 19, 2005 | 10:07 AM
tony n.'s Avatar
Default Re: Installin a turbo on a ls need help! (Civicman86)
FMU for now
Tming done either dizzy? do you have any pictures of where u ran ur vac from
Old Apr 19, 2005 | 11:58 AM
Spoold_R's Avatar
New User
Vac should be taken from the intake manifold, not the brake booster. Taking the vac from the brake booster is dangerous. You can T off of any vaccuum source coming from the intake manifold. I suggest a vaccuum manifold to do it clean.
Old Apr 19, 2005 | 12:01 PM
Evanmb44's Avatar
Default Re: Installin a turbo on a ls need help! (Spoold_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoold_R &raquo;</TD></TR><TR><TD CLASS="quote">Vac should be taken from the intake manifold, not the brake booster. Taking the vac from the brake booster is dangerous. You can T off of any vaccuum source coming from the intake manifold. I suggest a vaccuum manifold to do it clean.</TD></TR></TABLE>
it is fine to tee off the brake booster. where do you think vacuum manifolds get their vacuum source from eh?
Old Apr 19, 2005 | 05:29 PM
s2kdre's Avatar
Default Re: Installin a turbo on a ls need help! (Turboaddict)
you dont want to retard the timing at all,
Old Apr 19, 2005 | 07:34 PM
Na-Spirit's Avatar
I t'd off from the fuel pressure regulator, that to my bov, and for my wg i used the fitting off my turbo....the fmu will get you by at low boost, but look into uberdata, and turboedit if your obdo for tuneing.
Old Apr 19, 2005 | 08:20 PM
blackeg's Avatar
Default Re: (mugenknockoff)
retard timing at the distributor a few degrees, or get an msd btm (but u can get other management for the same price). dont run too much boost without proper timing retard, hondas really dont like that.
run the wastegate from the brake booster BEFORE the check valve. the wastegate should be the only source off that vacuum line. bov and boost gauge can come off the fpr vacuum line
Old Apr 19, 2005 | 08:42 PM
nsx411's Avatar
Default Installin a turbo on a ls need help! (boosted2cam)
What year Ls motor are you installing the kit? Just to let you know uberdata or hondata is good resource to chipping your ecu. Honestly, I dont recommend getting vacuum from brake booster. Get it from intake manifold. uberdata or hondata could be used as fuel management. I am currently boosting with greddy TDO5 turbo and chipped ecu with uberdata.
Old Apr 19, 2005 | 10:06 PM
Treblarefils's Avatar
Here is a pic of my setup if you look closely on the back of my intake manifold you can see where i tee'd off of the brake booster to my vacuum manifold. I have had it like this for a while and have seen no negative side effects and many people here run it that way.
Old Apr 20, 2005 | 02:12 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Installin a turbo on a ls need help! (Treblarefils)
get a vacuum manifold. looks a lot clean. as far as retarding the timing, you do that with a timing gun and turning of the dizzy. ditch the FMU and get better fuel management.
civiceg8boy
20
Sep 21, 2009 01:26 AM
J-HAWK
Feb 4, 2006 05:58 PM
Team Underground Teg
May 2, 2005 04:49 PM
iluznxpnoi
Jul 7, 2001 02:08 PM
