Clicking noise 400 miles after new clutch
Old Apr 15, 2005 | 02:56 AM
FkingSUV's Avatar
Default Clicking noise 400 miles after new clutch
After installing a new exedy stage 1 i took it easy for the first 400 miles. yesterday i beat on it for the first time. just 2 pulls 1-2-3. As i get back to my house i knowtice theres a clicking noise while depressing the clutch and i can feel the clicks in the pedle. Whad did i **** up?
Old Apr 15, 2005 | 05:11 AM
ironlung78's Avatar
Default Re: Clicking noise 400 miles after new clutch (FkingSUV)
when you say pulls, what are you running for a car, mods, turbo???
did you change the release bearing when you changed the clutch?
if so was it replaced with an oem bearing or aftermarket bearing?
did you lube the shaft and bearing when you put it back together?
did you readjust the clutch pedal to reflect your new clutch?
proper free play at the pedal when not engaged?
did you disconnect the slave cylinder when you pulled the clutch off?
did you rebleed the clutch after you were done?
we can help you, if you help us
Old Apr 15, 2005 | 06:11 AM
JDMSiGuy17's Avatar
Default Re: Clicking noise 400 miles after new clutch (sidesi)
bump for some good advise!
Old Apr 15, 2005 | 01:25 PM
FkingSUV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidesi &raquo;</TD></TR><TR><TD CLASS="quote">when you say pulls, what are you running for a car, mods, turbo???
we can help you, if you help us</TD></TR></TABLE>
Motor is a d15b.
Yes, release bearing was changed when the clutch went in with the unit suplied with the exedy clutch.
No lube (opps?)
readjusted the pedal
Proper free play.
slave cyl has been bleed.
damn, didnt even think about using lube on that shaft.... Think thats it?
As a side note, i drove the car to work thismorning and the clicking was gone.
Solstic
Jun 13, 2012 11:34 AM
VTECgsr00
Feb 7, 2006 09:30 AM
killerslp
Jan 25, 2004 05:35 PM
Mikey
Jul 5, 2003 09:52 PM
