b16a2 obd2a into 99 civic dx hatchback with CTR ecu..
Old Mar 17, 2005 | 04:06 PM
accordscantdrift's Avatar
Default b16a2 obd2a into 99 civic dx hatchback with CTR ecu..
OK, my friend just purchased a b16a2 from the cocky HMO. His motor was pretty clean but came with a cut harness and had a few little flaws. Anyway, they were out of regular ecu's so he ended up getting a CTR ecu. The problem is right now is that we need to figure the wiring on the car. We purchased an obd2a1 1998 civic ex wiring harness for some extra plugs but havent really chopped off parts yet. The "A" plug is on a separate harness that goes behind the dash. I guess the ex harness has the "A" plug on the engine harness. What do I do to make it work with the CTR ecu. A couple of us have heard that ctr's firing order is backwards from a normal b16a2 which I am doubting. To sum things up we have an obd2b car with an obd2a motor and ecu. We also have a spare ex harness laying around. I dont have time to spend hours searching so hit me up at accordscantdrift@hotmail.com, accordscantdrift on aol, msn, and yahoo. Thank you!!
Old Mar 18, 2005 | 07:22 PM
EK9 B16B TSL's Avatar
Default Re: b16a2 obd2a into 99 civic dx hatchback with CTR ecu.. (dicksonrd)
is the ecu an obd2a? if not, then the harness you got is useless cuz the ecu plugs are different between obd2a and obd2b. i would just get a new b16a2 harness, theyre usually not too hard to find. this should match right up to the obd2b ecu and since your car is obd2b there shouldnt be any problems. oh yeah and if you want a p2t ecu (00 b16a2 ecu), i got one.
Old Mar 19, 2005 | 09:17 AM
Default Re: b16a2 obd2a into 99 civic dx hatchback with CTR ecu.. (EK9 B16B TSL)
The ecu we have is obd2a. The engine is obd2a. We have the ex harness that is obd2a also. The problem is that the car is obd2b so we ended up having 2 "A" plugs when we use the ex harness. So far I have heard that Im supposed to use the ex harness and its "plug and play". The way I see it is that I need to use the ex harness. Pull the pins out of the "A" plug in the obd2b harness and find thier spot in the ex "a" plug. Am I wrong?
Old Mar 20, 2005 | 08:32 AM
no one?? bump
Old Mar 23, 2005 | 12:36 AM
kinvid22's Avatar
Default Re: (dicksonrd)
you will need the obd2b ex or si harness to make it work for 99 hatch. the dash plugs from the 96-98 civic won't plug in to your 99-00 dash
Old Mar 23, 2005 | 05:24 AM
VTECVillain's Avatar
You will need a complete 99-00 OBD2B EX or Si harness if you want it to be as close to plug and play as possible with minimal wiring. Of course you can reuse the stock DX harness and add the necessary wiring as well. Then you will need an OBD2B to OBD2A ECU adapter harness so that the CTR ECU will plug in. DO NOT try using a 96-98 harness in the 99 chassis!
da59block
14
Nov 11, 2011 12:33 PM
JR_98spec-0315
Jun 21, 2011 09:32 PM
EKcivicEK
Oct 25, 2009 09:00 AM
andyjt
11
Nov 26, 2006 05:57 PM
spektrum
Nov 23, 2002 04:15 PM
