Idle drops at stops
Old Mar 14, 2005 | 07:47 PM
faSHOwidIT's Avatar
Default Idle drops at stops
Eversince I got my motor tuned, the idle would be a little above 1k when just coasting and right when I come to a complete stop, the idle would just drop down to like 600rpm and sometimes die. In the mornings I have a hard time starting the car and getting it to idle. It would start and then the idle would just die out. What can be the possible cause?
Old Mar 15, 2005 | 06:35 AM
PrettyLude's Avatar
what year and engine and setup do you have?
Old Mar 15, 2005 | 06:37 AM
CompressionFed's Avatar
Default Re: Idle drops at stops (faSHOwidIT)
Check your fast idle valve. Sometimes they back out and just need a few turns. Also adjust the little screw on your throttle body. One more thing to look at is the IAC.
These are some good places to start looking.
Old Mar 15, 2005 | 06:57 AM
Dragline's Avatar
Sound like you need to take it back to who ever tuned it,If your running a EMS it's definetly a tuning issue.
Old Mar 15, 2005 | 07:19 AM
mmuller's Avatar
Mad Scientist
check base idle.
unplug the iacv and see what it idles at, it should be 500/550.
Old Mar 15, 2005 | 11:39 AM
faSHOwidIT's Avatar
Yea i did adjust the idle on the thottle body but then it still didnt help it from dropping down. It would keep the car on in the morning but then for some reason it went back to the way it was before. Engine is 93 ls block with obd1 b16 head. Could it be the +2 on the intake cam when he tuned it? A little more info on the fast idle valve please, did a search and nothing came up. Thanks
Old Mar 15, 2005 | 07:07 PM
faSHOwidIT's Avatar
Using vafc.
Old Mar 16, 2005 | 04:53 AM
SuperImport's Avatar
This might sound stupid but check your intake it could be clogged up.. if your cars not breathing right and there's stuff in your intake.. it's a legit reason
Old Mar 16, 2005 | 09:33 PM
faSHOwidIT's Avatar
Intake is not clogged. Anything else?
Old Mar 16, 2005 | 09:48 PM
onepoint6i's Avatar
Default Re: (faSHOwidIT)
your IAC or EACV is the part on the back of the manifold by your throttle body..it has a plug going to it and two coolant hoses...this controls your idle on cold starts
try doing the idle learn...unplug the negative cable at the batt for 2 mins, connect it back, tighten it, turn on the engine and let it idle without touching the throttle pedal at all for ten minutes..then shut it off turn it back on and check to see if that helps...
Old Mar 16, 2005 | 11:33 PM
faSHOwidIT's Avatar
K i'll do the idle learn. Also what I noticed when i went to go get my car tuned, when they did the ignition timing, they didn't jump the harness on the passenger kickpanel. Is that OK?
Old Mar 17, 2005 | 05:27 AM
Used2beAb16's Avatar
what kind of cams?? I def could be the +2 on the intake cam. Mine was out of time about 1 degree and it did the exact same thing.
Old Mar 17, 2005 | 07:05 AM
faSHOwidIT's Avatar
Bc3+
Old Mar 18, 2005 | 11:12 PM
faSHOwidIT's Avatar
Bump
Old Mar 25, 2005 | 02:07 AM
faSHOwidIT's Avatar
So what can my problem be?
spock_rocker
Oct 17, 2007 08:11 AM
carblegal
Dec 25, 2004 09:51 PM
SilverSellout
12
Feb 27, 2004 12:48 PM
killa_lude
Aug 16, 2003 08:33 AM
