help with electrical misfire on current draw
Old Mar 24, 2005 | 10:19 PM
VAAJ's Avatar
Default help with electrical misfire on current draw
After days of troubleshooting i have found that whenever theres a current being draw, all of the engine sensor voltage go out of range or spec. For example at idle everything seems fine, but whent the radiator fan comes on you can hear and feel the misfire.
Another example is when vtec kicks in, the engine bog or hesistate real bad. It only hesistate right when the vtec solenoid draws the current. It does this on every gear.
I'm pretty much stuck on this electrical problem.
heres a little background on the car;
91 crx b16a1 converted to OBD1 BAR certified.
Old Mar 25, 2005 | 04:22 AM
JimBlake's Avatar
Default Re: help with electrical misfire on current draw (VAAJ)
When stuff that's supposed to be unrelated, starts affecting each other, it's usually bad grounds. Clean up all your grounds, check all of them for the wire itself being loose/corroded inside the crimped connector.
If that's not it, do the same for the (+) battery power distribution from the main relay. That powers all kinds of stuff like injectors, most relays, & even the ECU itself.
B17
Nov 7, 2016 12:29 PM
gearhead2228
Jan 13, 2015 07:51 PM
NoName487
Nov 14, 2012 08:10 AM
randle2318
Nov 20, 2007 06:36 PM
VAAJ
Mar 25, 2005 08:31 PM
