VSS sensor went out again...
Old Feb 25, 2005 | 03:30 PM
unknown0001's Avatar
Default VSS sensor went out again...
Hey guys....I've searched before and I have already posted a year or so ago about a problem where my speedometer would stop working and sometimes it would kick in.
so last spring I went out...found a good VSS sensor and put that into my transmission and it worked fine. Right before winter came the speedometer went out again.
is this just my dam luck? does my civic hate winter?
My speedometer will kick in sometimes and I do get the check engine light but this is just pure gay.
Could this be something else that I have overlooked?
or should I just get another vss sensor?
*edit*
I've been in electronics class all days so I meant VSS(vehicle speed sensor) NOT VCC
Old Feb 25, 2005 | 05:12 PM
Default Re: VSS sensor went out again... (Mr.RHTuner)
up
Old Feb 26, 2005 | 04:42 AM
up for some help
Old Feb 26, 2005 | 05:54 AM
2lua's Avatar
did you check the wiring connection to see if it still good? also check the plug itself to see if it making contact, and clean.
Old Feb 26, 2005 | 07:41 AM
Sly_Samba's Avatar
HTBATRACER
Default Re: VSS sensor went out again... (2lua)
replace the speedometer if you havent already...
Old Feb 26, 2005 | 12:44 PM
Default Re: VSS sensor went out again... (tihul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tihul &raquo;</TD></TR><TR><TD CLASS="quote">replace the speedometer if you havent already...</TD></TR></TABLE>
is there a reason specifically why I should replace my speedometer? like what would go wrong with it as I don't think it's the speedometer
Old Feb 26, 2005 | 07:37 PM
ideas anyone?
Old Feb 26, 2005 | 10:31 PM
EG1.8cT68's Avatar
Sounds like a speedo head to me. The actual unit that moves the needle. At the dealership I work at we use the PGM tester to see if the ECU is getting a signal from the speed sensor if it is then your cluster speedo is bad or possibly sticky as if you have a poor white face gauge install. But if the ECU is not receiving the speed then your speed sensor or speedo gear is bad.
Hope this helps.
Old Feb 28, 2005 | 02:43 PM
Default Re: (EG1.8cT68)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG1.8cT68 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a speedo head to me. The actual unit that moves the needle. At the dealership I work at we use the PGM tester to see if the ECU is getting a signal from the speed sensor if it is then your cluster speedo is bad or possibly sticky as if you have a poor white face gauge install. But if the ECU is not receiving the speed then your speed sensor or speedo gear is bad.
Hope this helps.</TD></TR></TABLE>
Thanks man. I'll contact honda and see if I can get that PGM test done on my car
kindness
Aug 31, 2012 11:20 AM
doubleoazn03
Sep 5, 2008 10:33 PM
hspoon
Aug 30, 2006 07:52 PM
98IntegraLSNonVtec
Dec 24, 2005 11:52 AM
vtectuner99
Aug 18, 2002 06:29 PM
