vehicle speed sensor problems
Old Aug 17, 2002 | 10:28 PM
vtectuner99's Avatar
Default vehicle speed sensor problems
I have a civic turbo d16y8 just got the check engine light today, i checked the code and it is the vehicle speed sensor. what needs to be done to fit the problem? Do i just replace the (VSS) or what ? thanks
Old Aug 17, 2002 | 11:01 PM
Incognito's Avatar
Default Re: vehicle speed sensor problems (vtectuner99)
The sensor itself usually doesn't go bad, because it's pretty much just magnets. You probably have a short in the wiring somewhere (check your O2 sensor wires. if the power grounds on the exhaust, it trips the VSS check engine. they're on the same circuit. I had this problem). Also, check your fuses. good luck.
Old Aug 18, 2002 | 06:29 PM
Default Re: vehicle speed sensor problems (Incognito)
thanks for the info
madnad
Sep 18, 2018 06:49 AM
DC2man
Mar 3, 2008 07:01 PM
98IntegraLSNonVtec
Dec 24, 2005 11:52 AM
unknown0001
Feb 28, 2005 02:43 PM
