B20B piston on B20vtec
Old Feb 21, 2005 | 12:26 PM
fbi's Avatar
fbi
Default B20B piston on B20vtec
*** sorry for english I speak french ***
I do some search and the answer are not always in the same direction.
I'm building a simple B20/vtec : b20b bloc with B16a2 head.
the bloc is stock and the head is stock and just milled a little bit (0.003 inch !?!?)
I have SIR head stud but I think ARP will be use in the setup.
The question is about the valve clearance. Some body told that it will clear with b16 cams and stock timming, some other told that it will not clear at all. I want to know if the valve will clear with SIR cams and no timming adjustement.
It will run on JDM P30, and I don't want to rev it to 8200rpm
tanks
Old Feb 21, 2005 | 12:37 PM
DSRxCandyh2bEG's Avatar
Default Re: B20B piston on B20vtec (fbi)
You shouldnt have any problems, especially if that is where you are revving to. I would use a chipped p28 ecu though. They just run better... Ive never personally used a p30 before but i know the p28 ecu runs better than a gsr (p72) ecu, at least on my setup... as far as valve clearances, i believe you should be able to use stage one cams from most manufacturers and still be ok... good luck with your setup...
Old Feb 21, 2005 | 12:48 PM
xTravBx's Avatar
Default Re: B20B piston on B20vtec (Candyh22EG)
Clay the motor!
http://www.c-speedracing.com/h...y.php
Old Feb 21, 2005 | 01:42 PM
EG-B20vtec's Avatar
Default Re: B20B piston on B20vtec (xTravBx)
Save yourself the headache and buy some JE or other brand B20VTEC pistons. The valve reliefs are already cut for VTEC sized valves.
An added bonus is the extra compression you will gain by not using those low compression B20B Pistons.
Old Feb 21, 2005 | 01:57 PM
non-VTEC's Avatar
you can find a nice set of forged pistons for decent prices these days that will always outperform the stock piston. the stock B20 piston doesnt give you enough compression to make any decent power.
i would recommend a set of 84mm wiseco 11.5:1CR pistons. there pretty affordible and very good qualitly and with 11:1+CR you can make good power for a everyday driven car.
good luck.
Old Feb 21, 2005 | 02:35 PM
fbi's Avatar
fbi
Default Re: B20B piston on B20vtec (non-VTEC)
I know that I can find aftermarket piston for b20vtec, but I want to run the setup with B20B piston for this summer. I just want to know if it's safe or not. If not, I will wait a little bit and buy wiseco pistons
tanks
Other poeple with stock B20B vtec ???
Old Feb 21, 2005 | 03:41 PM
Punkaddic's Avatar
demande à K-os sur ciq, cest exactement sa son setup et sa lair à très bien allé
Old Feb 22, 2005 | 10:23 PM
fbi's Avatar
fbi
Default Re: B20B piston on B20vtec (Punkaddic)
Other experience with B20B piston on stock b20/vtec ??
Old Feb 22, 2005 | 10:42 PM
irev210's Avatar
wont hit
you can run CTR ITR cams on a B20 with stock piston and be fine
just dont mess with the cam timing.
Old Feb 23, 2005 | 08:56 AM
fbi's Avatar
fbi
Default Re: B20B piston on B20vtec (irev210)
tanks a lot dude no more headache
Old Feb 23, 2005 | 08:58 AM
92sireg's Avatar
Hey irev210 just a question for ya on a b20z is there any valve clearance issue with a b16 head and ctr cam? I know there is no prob on b20b but not the z Thanks
Old Feb 23, 2005 | 09:02 AM
irev210's Avatar
Default Re: B20B piston on B20vtec (92sireg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92sireg &raquo;</TD></TR><TR><TD CLASS="quote">Hey irev210 just a question for ya on a b20z is there any valve clearance issue with a b16 head and ctr cam? I know there is no prob on b20b but not the z Thanks </TD></TR></TABLE>
nope, no clearance issues
PHX and P3F pistons both will clear with no problem with CTR or ITR pistons with the cam gears set at 0,0.
Old Mar 3, 2005 | 05:30 PM
Garrett's Avatar
My b20b have ITR cams, and stock 8.8 pistons notch
The head is removed why not notch it now?
If your upgrade your cams latter it won't be a good time to lift the head another
Si tu veux socketé ton ECU pour ensuite lui tuné un ship, je fais des P30 JDM Chippé
Contact moi sur ccq ou Darkside
Old Mar 3, 2005 | 05:48 PM
irev210's Avatar
Default Re: B20B piston on B20vtec (Garrett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett &raquo;</TD></TR><TR><TD CLASS="quote">My b20b have ITR cams, and stock 8.8 pistons notch
Well, it would be pointless to notch them because he wouldnt know what cams to put in, how much to notch them etc
Old Mar 3, 2005 | 05:52 PM
Garrett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">
Vtec head use intake valve 2 mm larger, just notch the pistons to accept those valves
Modified by Garrett at 2:28 PM 3/6/2005
Old Apr 13, 2005 | 05:20 PM
EG6R's Avatar
How necessary is it to notch the b20b pistons with large cams? Say, s2s2.
Old Apr 14, 2005 | 04:30 PM
Garrett's Avatar
Default Re: B20B piston on B20vtec (EG6R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6R &raquo;</TD></TR><TR><TD CLASS="quote">How necessary is it to notch the b20b pistons with large cams? Say, s2s2. </TD></TR></TABLE>
IT's an obligation
Old Jun 13, 2005 | 10:21 AM
timisyourfriend's Avatar
better safe them sorry, I notched and I'm using CTR cams.
Old Jul 7, 2005 | 09:38 AM
Phat_GSR's Avatar
Default Re: B20B piston on B20vtec (JZPerformance)
i am using GSr cams and stock b20b pistons and i have no problems.
Old Jul 7, 2005 | 07:31 PM
PURE Tuning's Avatar
They will clear with only .003 off of the head, I notch the piston valve relief for added clearence on thinner gaskets and more milled heads.
Old Jul 9, 2005 | 04:57 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">you can find a nice set of forged pistons for decent prices these days that will always outperform the stock piston. the stock B20 piston doesnt give you enough compression to make any decent power.
good luck.</TD></TR></TABLE>
The only problem with forged pistons is that you can't run them tight. They will tend to clatter and wear out fast, which is not an ideal situation on a daily driver.
j4s0n1337
Dec 15, 2022 06:13 AM
B Dap
Engine Management and Tuning
Dec 2, 2009 03:40 PM
upon1cbr
Aug 6, 2009 07:59 AM
FEIN4BOOST
Apr 15, 2009 01:56 PM
Speed_1
Jul 27, 2006 08:17 PM
