BC STAGE 2 camshaft?
I just bought a set of BC CAMSHAFT 4 my gsr and was wondering if I would have to redo my valves again which I just recently did one for my stock camshaft do to a rebuild. also can i run on a stock p28 ecu without chip. and would all the pin from a p28 n p72 b the same? or would i hav to change it as i change ecu?
Re: BC STAGE 2 camshaft?
No you can not run a stock P28 on a GSR. It will start the car and run but it will more than likely blow your motor.
You will not need to redo your valves, but you will need an aftermarket valvetrain.
Is your P72 OBD1? If yes it will be the same...just swap the ECU, make sure you get the P28 chipped for your set up first.
thanks n yes the head is fully built with shunk2 components beside the camshaft is gonna be BC. also my car use to have a d15b7 n i notice that all the pin are different. but i have re-pin a couple of them. i havent dont a swap with a non vtec to a vtec so its kind of confusing. hope it works n get it going.
VTECcnIT
02-16-2006 04:42 AM
Zion-I
02-12-2006 09:32 PM
CaptivaBlue
04-09-2005 03:54 PM
