Ls/V-tec setup--what to need??????????
Old Feb 8, 2005 | 06:09 PM
Reservation-Sensation's Avatar
Default Ls/V-tec setup--what to need??????????
whats all needed for lsvtec to go together? i hear b16 oil pump and gs-r head studs anything else?
Old Feb 8, 2005 | 07:42 PM
Combustion Contraption's Avatar
yeah, you need to ******* search.
Old Feb 9, 2005 | 06:03 AM
mnskateboarder's Avatar
here is a simple answer i found from a simple SEARCH complete parts list as stated in November Sport Compact Car
-B series VTEC head
-VTEC ECU
-B series VTEC dist
-90-01 LS head gasket
-94-01 GS-R head bolts
-94-01 GS-R timing belt
-94-01 GR-R knock sensor***
- -4 braided steel lines 22in. with female ends
-1/8" NPT female to 1/8" NPT female to 1/8" BSPT male on run pipe tee
-1/8" NPT male to -4 male straight adapter
-3/8" NPT male to -4 male straight adapter
-1/8" internal pipe plug
-1/8" NPT pipe tap
-3/8" NPT pipe tap
-14mm drill bit
-10.9mm drill bit
-12mmX1.25mm tap
***if you use Hondata you do not need to drill and tap the block for a knock sensor.
-so depending on which route you go you may need a knock sensor.
-also you can not use an LS dist. it mounts differently than a VTEC dist. along with the section that is used for timing/rotating i believe is also different.
-ARP rod bolts would be a great investment since they are considered the peak link in the LS/VTEC
or go grab the november sport compact car, which is where this list is originally from.
Old Feb 9, 2005 | 07:16 AM
Default Re: (mnskateboarder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mnskateboarder &raquo;</TD></TR><TR><TD CLASS="quote">here is a simple answer i found from a simple SEARCH complete parts list as stated in November Sport Compact Car
-B series VTEC head
-VTEC ECU
-B series VTEC dist
-1/8" NPT pipe tap
-3/8" NPT pipe tap
-14mm drill bit
-10.9mm drill bit
-12mmX1.25mm tap
or go grab the november sport compact car, which is where this list is originally from.</TD></TR></TABLE>
good job man. Ive been to short tempered lately to answer these questions.
Old Feb 9, 2005 | 08:12 AM
baphomet's Avatar
Default Re: (LsVtec92Hatch)
would a b16 timing belt work?
Old Feb 9, 2005 | 08:22 AM
no, the deck height is different. b16 is too short.
Old Feb 9, 2005 | 12:19 PM
Hapexamendios EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">yeah, you need to ******* search.</TD></TR></TABLE> lol
Old Feb 9, 2005 | 05:45 PM
Hey, **** You!!!!!!!!!!!
Old Feb 9, 2005 | 06:19 PM
mmuller's Avatar
Mad Scientist
Default Re: (Reservation-Sensation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reservation-Sensation &raquo;</TD></TR><TR><TD CLASS="quote">Hey, **** You!!!!!!!!!!!</TD></TR></TABLE>
hey buddy you need to chill out... not a good way to start here on h-t
Old Feb 9, 2005 | 06:31 PM
GWInquisitor14's Avatar
Default Re: (mmuller)
go to http://www.goldeneaglemfg.com and buy their LS/VTEC conversion kit, it will save u the hassle. The knock sensor is only needed if u run a DOHC VTEC ecu. many ppl run chipped ecus that do not need the knock sensor. I just finished mine and i ended up using a P30 ECU and taped out the hole in the upper part of the head and put the knock sensor there. Many ppl drill and tap the alternator bracket but u need to remove the engine to do that. My way works good and it will sense knock. An issue stated many times is the timing belt. If you use a VTEC water pump, u need the vtec belt. If u use the non-vtec water pump, use the non-vtec timing belt. Its recomended that u use the vtec water pump. I am going to put one when i change my timing belt this spring.
JDMbull
Nov 8, 2006 12:49 PM
LSRracing95
Sep 23, 2005 10:17 PM
AttikTuning
Jun 25, 2003 06:42 PM
jedi27sith
Jun 11, 2003 02:34 PM
drewlee
May 19, 2003 04:54 PM
