My car won't move! Is it stuck in gear?
Old Feb 7, 2005 | 04:02 PM
chemical's Avatar
Default My car won't move! Is it stuck in gear?
I was driving about a week ago and i turn around and come to a full stop, I put it into first and start to go and it just stalls as if I didn't give it gas and let the clutch out. I turned it back on and tryed to put it into gear but it wouldn't go into any gears, even reverse.
I turned the car off and put it in first then turn the car on and tryed to go and it died again as if I wasn't giving it gas. The motor revs fine and idles etc if clutch is in but if you let the clutch out even in neutrel the car dies. I have no idea what the problem is exactly.
Do I need to buy a new transmission? Brand new b18b1 from Hmotorsonline.com with a GSR tranny that's seen boost before. TIA.
Old Feb 7, 2005 | 04:06 PM
cxSHOE's Avatar
Default Re: My car won't move! Is it stuck in gear? (chemical)
sounds like your gear selector inside the trans is stuck. i would open the trans up and see whats wrong. its not hard. theres a post on how to do it in the archives somewhere.
Old Feb 7, 2005 | 04:18 PM
honda_S's Avatar
release the ebrake
Old Feb 7, 2005 | 04:41 PM
chemical's Avatar
Default Re: (8y61d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8y61d &raquo;</TD></TR><TR><TD CLASS="quote">release the ebrake</TD></TR></TABLE>
Noone thinks you're funny. Your post doesn't even make sense.
Old Feb 7, 2005 | 04:46 PM
WHiTETYPEs's Avatar
Default Re: (chemical)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chemical &raquo;</TD></TR><TR><TD CLASS="quote">
Noone thinks you're funny. Your post doesn't even make sense.</TD></TR></TABLE>
His post doesn't make sense? It makes perfect sense if you "think hard enough" Anyways what the first guy said could be the problem don't be such an A hole to other members your always gunna get people who try and make jokes out of everything so just deal with it
Old Feb 7, 2005 | 04:57 PM
honda_S's Avatar
Old Feb 7, 2005 | 05:06 PM
95sihb's Avatar
Default Re: (8y61d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8y61d &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
LMAO......all-kidding around , look into your shift fork it could have broken and jamd itself not letting you select gears...like cxshoe said look do a search you will find it ....look also into the faq in the top of the forum page
Old Feb 13, 2005 | 04:00 PM
99exd16y8's Avatar
Default Re: (95sihb)
lmao
Old Feb 13, 2005 | 04:32 PM
EF CRx_N_motion's Avatar
Default Re: (99exd16y8)
does it stay still when u push the clutch in ?
Old Feb 13, 2005 | 04:47 PM
JDMlyfestyle's Avatar
most likely your shift fork had it happen to me twice. with z6 tranny's
jarred1414
Dec 29, 2018 02:39 PM
sing
Jan 4, 2007 02:12 PM
turbogeezercivic
Jul 31, 2004 09:02 PM
blueeg
Dec 7, 2003 05:49 PM
2000si
Sep 24, 2003 02:39 PM
