Having a problem getting in gear
Old 07-31-2004, 04:15 PM
turbogeezercivic's Avatar
Default Having a problem getting in gear
I have a gsr motor with b16 trans. welll the other night i was in 1st gear witht the clutch in and car started to lunge forward so i poped it out of gear, now car wont go in gear while car is running...........any ideas what it might be lat me know thanks
turbogeezercivic is offline
Old 07-31-2004, 04:16 PM
vtecpsyco's Avatar
Default Re: Having a problem getting in gear (turbogeezercivic)
bro i have the same fuking problem.so its two people that want to know,and dont waste your time bleeding the clutch that wont fix it i already tried.
vtecpsyco is offline
Old 07-31-2004, 04:22 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogeezercivic &raquo;</TD></TR><TR><TD CLASS="quote">I have a gsr motor with b16 trans. welll the other night i was in 1st gear witht the clutch in and car started to lunge forward so i poped it out of gear, now car wont go in gear while car is running...........any ideas what it might be lat me know thanks </TD></TR></TABLE>
start with the clutch fluid, if its full inspect the shift linkage. if both are OK looks like its a clutch problem.
Kamin is offline
Old 07-31-2004, 04:26 PM
SprayinCX's Avatar
Default Re: Having a problem getting in gear (Kamin)
could be a broken shift fork. which would be internal. thats what happens when that breaks. you can cram the crap out it into 3rd and you can still drive it for awhile.but i would advise against that.
SprayinCX is offline
Old 07-31-2004, 04:45 PM
Kamin's Avatar
Default Re: Having a problem getting in gear (SprayinCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinCX &raquo;</TD></TR><TR><TD CLASS="quote">could be a broken shift fork. which would be internal. thats what happens when that breaks. you can cram the crap out it into 3rd and you can still drive it for awhile.but i would advise against that.</TD></TR></TABLE>considering he probably cant go into any gear i dobut its a shift fork.
Kamin is offline
Old 07-31-2004, 08:36 PM
SprayinCX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">considering he probably cant go into any gear i dobut its a shift fork.</TD></TR></TABLE>
is sounds just like what happened to my friends itr tranny and he litterally jammed it into 2nd. then we had to drive about 30 miles back to his house. still in second gear.
Old 07-31-2004, 09:00 PM
i dont think its the shift fork because when my car is cold it gos into gear fluids are fine too... im thnking maybe clutch cause when its warm i put it into first push the cluth in it starts to lunge forward im goin to try the shift lingage hopfly thats it again more suggestions maybe something else let me know... and thnks again for all your help
Old 07-31-2004, 09:02 PM
honda9369's Avatar
start with the clutch fluid, if its full inspect the shift linkage. if both are OK looks like its a clutch problem.</TD></TR></TABLE>
honda9369 is offline
John 07
09-11-2012 07:18 PM
FormerDSMer
09-04-2009 09:26 AM
JDMGSR-T
10-27-2006 02:48 PM
95greenteg
05-11-2006 04:50 PM
eMbrace
05-14-2005 07:47 AM
Quick Reply: Having a problem getting in gear
  • Ask a Question
Question Title:
Description:
