VTEC and Speedometer not working.
Old Jan 30, 2005 | 08:40 AM
gsr984dr's Avatar
Default VTEC and Speedometer not working.
I recently had an exedy clutch and flywheel installed in my car and now my VTEC and my speedometer doesn't work. I read in the forum that it could be caused by low oil pressure so I immediately did an oil change on the car and it's still experiencing the same thing. Now my check engine came on.
Does anyone know what the problem could be? Has anyone experienced this same problem?
Old Jan 30, 2005 | 08:44 AM
RotiEatter's Avatar
Ditto
Default Re: VTEC and Speedometer not working. (gsr984dr)
If your speedometer isn't working VTEC won't work either. Make sure your VSS is plugged in, they may have forgot to plug it back in.
Old Jan 30, 2005 | 08:46 AM
eL's Avatar
eL
Sounds like the answer
Old Jan 30, 2005 | 08:47 AM
gsr984dr's Avatar
Default Re: VTEC and Speedometer not working. (RotiEatter)
I'm new to all this and don't want to sound too dumb. What is the VSS and where is it located?
Old Jan 30, 2005 | 08:48 AM
T4eg's Avatar
VSS is vehicle speed sensor it its straight down from the throttle body on top of transmission right above where the axles go in.
Chris
Old Jan 30, 2005 | 08:50 AM
eL's Avatar
eL
There's only one bolt on the VSS correct?
Old Jan 30, 2005 | 08:51 AM
AllmtrSlut's Avatar
Default Re: (eL)
is the ecu throwing any codes??
Old Jan 30, 2005 | 09:09 AM
gsr984dr's Avatar
Default Re: (AllmtrSlut)
I dont know how to check for codes. I checked and made sure all the sensors (plugs) were connected all the way.
This is a 00 Si that is having the problem. Just so you all know.
Thanks.
Old Jan 30, 2005 | 09:11 AM
moreno's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">If your speedometer isn't working VTEC won't work either. Make sure your VSS is plugged in, they may have forgot to plug it back in.</TD></TR></TABLE>
damn, i never knew that. now i know though
jlacoy82's Avatar
71.192.16.183
Default Re: (gsr984dr)
You would know there was a code being thrown if your check engine light (CEL) was on.
Old Jan 30, 2005 | 10:13 AM
RotiEatter's Avatar
Ditto
Default Re: (jlacoy82)
Take the car back to whoever installed the clutch for you, they should be fixing this problem not you, judging by your posts I am assuming you didn't install your own clutch.
Old Jan 30, 2005 | 10:17 AM
dogfood's Avatar
get yourself a haynes or a chiltons, it will answer a ton of little questions for you
jvg
May 27, 2008 12:09 PM
2.2 teg
Jun 4, 2007 09:47 PM
civicseth
16
May 18, 2005 08:51 PM
Freshazzburu
Oct 17, 2004 10:12 PM
blykins
Oct 30, 2001 10:50 PM
