broken header studs!!
Old Jan 26, 2005 | 09:00 PM
Jdmglenn's Avatar
Default broken header studs!!
i was unbolting my header from my head and two of the studs just plain broke and are basically flush with the surface........i tried to get a drill in between the head and radiator but there is just NO room
how do you guys do this???
Old Jan 27, 2005 | 08:39 AM
dwnthehatch's Avatar
Default Re: broken header studs!! (JdmGlenn)
Get a right angle drill attachment.
Then follow these instructions. https://honda-tech.com/zerothread?id=567450
Old Jan 27, 2005 | 12:35 PM
Honda Hick's Avatar
Default Re: broken header studs!! (dwnthehatch)
I got real lucky when 1 was broken on my head. I started drilling the stud and it started spinning on me. I was able then to stick a EZ-Out in there and pull it out. You are either going to have to get a right-angle drill or pull the head/engine to get that out.
Next time you have trouble getting a nut off use some heat. This works every time. Coat the nuts with PB blaster for a few days beforehand and then heat up the NUT with a torch (even a propane one will work). Keep the heat on there and eventually you will be able to loosen up the nut.
Old Jan 27, 2005 | 01:26 PM
THCk20eg's Avatar
take the radiator out if thats all thats holding you back.
Old Jan 29, 2005 | 02:41 AM
CRX-ZC's Avatar
Well, if you have a MIG welder, just weld a nut on broken stud and then unbolt it
Old Jan 29, 2005 | 02:44 AM
CRX-ZC's Avatar
here you have, how to do it;
http://www.geocities.com/jim_m....html
you can weld a nut directly to a stud through it's hole, no need to weld a washer first
Old Jan 29, 2005 | 03:24 PM
sabotage7's Avatar
that sux! happened to me too, but only one stud, not two!....i didnt trust myself drilling something into my head, my hands get shaky sometimes, so i took my car up to my friends shop and he did it for me for free......he does that kinda stuff all the time and even had a special tool for screwing/unscrewing studs!
good luck!
Old Jan 29, 2005 | 04:43 PM
HondaGuy02's Avatar
Banned
Default Re: broken header studs!! (sabotage7)
sucks! i know.. ive been rollin around with a broken off head stud for months sounds hedious too...
Old Jan 29, 2005 | 05:27 PM
sabotage7's Avatar
Default Re: broken header studs!! (HondaGuy02)
i was lucky enough that mine wasnt leaking or anything bc of it!
happens to the best of us! actually, now that i think about it, it even happened on my last car too! lol
Old Jan 31, 2005 | 09:31 AM
hondapreludejay's Avatar
PB and torch flames are good break prevention. Rusty fasteners suck and nothing is worse than nasty exhaust fasteners. Also, whenever possible run the engine up to operating temp first, a good hot block insures all metals involve will be good and expanded.
Old Jan 31, 2005 | 09:50 AM
SJcivic's Avatar
Default Re: broken header studs!! (hondapreludejay)
Anti-seize is your best friend when your dealing with anything on the exhaust.
Rich
TravisCadello
63
Oct 24, 2008 07:14 AM
shutta
Dec 7, 2005 10:49 AM
Liquidgsr
Mar 7, 2005 09:17 AM
pub
Mar 21, 2003 02:51 PM
PatrickGSR94
Apr 28, 2002 03:56 AM
