Critique and Criticize my setup PLEASE!
Old Jan 13, 2002 | 12:30 AM
AllMotorITR's Avatar
New User
Default Critique and Criticize my setup PLEASE!
Hey Turbo Gurus! I have a potential turbo setup for my R that I would love for you guys to critque... Anything you think I should add let me know, and anything you think I should remove let me know.... I plan on boosting 18lbs max for the strip... But the most part, for little street races and such 14-15lbs... What do you guys think of my setup?
- Drag III Turbo Kit
- J&S Safeguard Ultra Version 2
- Thermal R&D 3" Turbo Catback
- JE SRP Pistons 9.0:1 Compression
- Eagle ESP Connecting Rods
- Apex'i AVC-R
- Greddy Turbo Timer
- RC 550cc Injectors? (bigger size or no?)
- Tial Wastegate
- Arturbo 3" Downpipe
- Hondata Stage 4b
What clutch would you guys recommend too?
Old Jan 13, 2002 | 06:59 AM
AlphaKennyWun's Avatar
Default Re: Critique and Criticize my setup PLEASE! (1 FAST R)
I have a clutchmasters stage 4....it will take you a few months to get used to it...I would recommend a stage 3 unless you plan to DO ALOT of Drag Racing. Driving in traffic with stage 4 is a pain..almost 3 months later im finally used to it.
Set up sounds good. My criticism is to get Crower instead of Eagle rods b/c I was going to get the Eagle until RACE engineering told me the Eagle rods have sometimes slapped the side of the block and sometimes need to be shaven down....Same thing goes with the SRP pistons...they cracked on two people I know get JE. (i know JE makes SRP but theyre not the same thing). I dont know why you need the J&S Safe guard spend the money on tuning instead. I dont know why you need the Stage 4 Hondata....Stage 3 will do the 18 lbs you want. Injectors might be too small go with 750 cc you will never need to change them again. I also wouldnt get a AVC-R. I would get a manual boost controller for like 50 bucks. But if you got the money then hey why not?
Spend lots of attention on the head...SS valves, dual springs, retainers. I broke a valve b/c the stock springs were too soft...piston smacked the valve and broke it sending it into the chamber..at only 9 lbs. What happened was good-bye motor at only 25k miles!!!! THE VALVE TRAIN IS VERY WEAK. I have a turbo GSR by the way and already bought the JE pistons and crower rods.
Hope this helps...of course this is my opinion I know others will disagree but Ive had turbo in my GSR since 1997 I think that counts for something.
[Modified by SO3Burner, 4:39 PM 1/13/2002]
Old Jan 13, 2002 | 07:00 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Critique and Criticize my setup PLEASE! (SO3Burner)
Sounds like a very good set up to me...
Old Jan 13, 2002 | 07:05 AM
BoostinDC2's Avatar
Default Re: Critique and Criticize my setup PLEASE! (Arturbo)
for a clutch i would go with ACT Xtreme PP and a 6 puck sprung hub
Old Jan 13, 2002 | 07:50 AM
meanteg's Avatar
New User
Default Re: Critique and Criticize my setup PLEASE! (BoostinDC2)
ATC A-14XTSS awesome grip, and smooth engagement.
So3 burner: You think that 550cc injectors won't be sufficicient for 18 psi ? Someone else feels the same way?
Old Jan 13, 2002 | 08:07 AM
falcongsr's Avatar
What is this crap?
looks good, or as they say here: it looks tiiiite. hah. whats that look like? about $7k?
evz
22
Aug 22, 2007 08:52 PM
SweepeR 7
Oct 29, 2003 08:37 AM
turboex
Apr 3, 2003 06:39 PM
AllMotorITR
Nov 30, 2001 03:03 PM
