You pick the turbo setup, the motor is allready built. help out turbo guys
Ok heres the setup
84mm Dart block
jun flywheel
crower rods
edyne 9.2to1 pistons
underdrive pully
stage 3 clutch
GSR tranny
quaife LDS
GSR head
GSR cams
JG gears
JG head Oversized valves, springs rets. all that stuff
JG throttle body
Hondata 3b
We have allmost every internal part i can think of for this car. the owner is looking for at least 400hp. What turbo/manifold/injector size should we go with to get the best results.
[Modified by turboex, 10:40 PM 4/3/2003]
84mm Dart block
jun flywheel
crower rods
underdrive pully
stage 3 clutch
GSR tranny
quaife LDS
GSR head
GSR cams
JG gears
JG throttle body
Hondata 3b
Re: You pick the turbo setup, the motor is allready built. help out turbo guys (turboex)
Talk to DiRep (Chris), Arturbo (Art), MotorMatrix.com (Mike), or b18bturbo (Viren). Those guys can point you in the right direction.
Re: You pick the turbo setup, the motor is allready built. help out turbo guys (2.0L Turbo)
Sounds good man, where you guys at, hook me up with the info and ill order the setup from ya. thanks again
1 Post
whats your budget? If it was pretty high, I would reccomend the Hytech turbo kit.
https://honda-tech.com/zerothread?id=369711
Inovative turbo- t3/60-1 stage 5 wheel with a .63 a/r should do the trick.
RC injectors at least 720cc.
Re: You pick the turbo setup, the motor is allready built. help out turbo guys (ekb18c)
Re: You pick the turbo setup, the motor is allready built. help out turbo guys (0x64)
I absolutly love my sc61 with a stage 5 wheel. It spools just like my 60-1 hifi with a stage 3 wheel and pulls much better up top.
mando_eg2
09-03-2013 08:12 AM
