Nothing ever goes right Hondata problem plz help
Old Jan 13, 2005 | 10:07 AM
ebpcivicsi1234's Avatar
Default Nothing ever goes right Hondata problem plz help
Car is a 99 si b16a2 with a peak boost turbo kit
p28 ecu hondata 200b
here is the problem i have not started the car ter as i cant but i think it doesnt matter...I have been told 3 different things from 3 people.My problem is my hondata led is blinking and i cant connect my labtop to datalogger it justs keeps connecting.
First guy says its fine is supose to blink as long as its a steady 3-4 sec blink if it blink faster theres something wrong with either the hondata or ecu and if it blinks slower same thing
I called hondata and he says that the basemap is inccorec for my car but would that really make the led flash so he said call my dealer i got it from,and my dealer said what i medntioned above
And everything thing i read on here about it is there is no communication bewteen the too..Iam lost i dont know what i should do
Old Jan 13, 2005 | 10:19 PM
turtle-eg's Avatar
Default Re: Nothing ever goes right Hondata problem plz help (ebpcivicsi1234)
Did you count how many blinks before it repeats the blinking(by a longer than usaul pause)? The blinking is giving out a code.
If everything is correct, when you turn the key on, the hondata box should blink once and stay on (solid).
Old Jan 14, 2005 | 01:39 PM
Spunkster's Avatar
It will not connect or datalog if it is blinking. It sounds liek you have an incorrect basemap. Contact your dealer or tuner for a basemap and see if they can resolve the isssue. The only other possible probelm is you have a poor soldering job on the ecu you are using. Either way, your dealer/tuner should be able to resolve this for you.
Old Jan 14, 2005 | 01:57 PM
HXMan's Avatar
You probably got a blank chip. Each time I got hondata I had that problem.
Old Jan 14, 2005 | 03:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Nothing ever goes right Hondata problem plz help (HXMan)
make sure the chip is installed correctly also.
Old Jan 14, 2005 | 03:24 PM
Spunkster's Avatar
The chips are always sent blank....your dealer is the one who burns the basemap.
Old Jan 14, 2005 | 03:29 PM
Default Re: Nothing ever goes right Hondata problem plz help (Spunkster)
my dealer said sent it back and they will try burnin g it agian
Old Jan 14, 2005 | 04:29 PM
brandond's Avatar
B A N N E D
hey bro i just got my tuned hondata s100 back from south florida performance and my fuel pump wasnt priming so i called them and he said open the ecu so i did and then he said is it blinking i said yes he said make sure the first 4 pin connectors from right to left line up with the white box that is under neath it connecting it so i did right away i heard my fuel pump prime and the blinking light went away so that might be your problem
Old Jan 14, 2005 | 04:45 PM
JusT a Cx's Avatar
Default Re: Nothing ever goes right Hondata problem plz help (brandond)
yo the blinking red light is a sign of unprogrammed chip... theres nothing on it.....
boostdvic
Aug 6, 2008 09:01 AM
shyboi4u
May 11, 2006 09:53 PM
THEUSED
Apr 1, 2006 04:08 PM
vtekthis
Jan 11, 2004 10:41 PM
qwklude82
Mar 21, 2003 02:09 PM
