hondata s200 acting up
i bought a boosted coupe about 3 weeks ago and the kid had did all the work to it and he put in hondata s200....well it keeps like messing up my rev limits cause the wire connector that hooks up to the hondata ecu is loose. at times i'll drive and i would have to shift at 3 grand cause the car bogs once i hit cause the damn connectors....i was wondering if anyone on here has some experience with the whole hondata program and can help me fix the problem. the car needs to be tuned but i dont want to go get it tuned with it still having that problem with the hondata making my car bog at 3500-4000 rpms.
Re: hondata s200 acting up (boostdvic)
If you have damaged wiring then you need to either fix it or replace it. I would suggest contacting your nearest Hondata dealer for some assistance and get it tuned.
Re: hondata s200 acting up (Spunkster)
more then likely, if you go to a tuner thats already familar with the s200 unit then they will be able to fix your problem.
2 birds with 1 stone,
now get the damn thing tuned man!
Re: hondata s200 acting up (JdelMsolG)
there is a red light that is in the hondata....it either is always on, blinking red or off....what should the light be doing at all times....i think its supposed to be on at all times cause it seems to do ok...and when its blinking thats when is seems to be acting up and i think it did work once with the light off....im not too sure and i would just like to know for when i go to fix it
