Timing gun with no dial....
Old Jan 12, 2005 | 01:09 AM
d15b7racer's Avatar
Default Timing gun with no dial....
i have this super old school craftsman timing gun and i was searching on how to adjust timing and most of them say something about adjusting the dial to this and then lining up with this mark. Well i dont have that dial so what mark do i use. Its a d16z6 motor and the crank has the three lines....and then the one white TDC line. so after i warm up my car and jump the connector....hook up everything....flash it and then line up the mark to..............????? Red mark or TDC mark?
Old Jan 12, 2005 | 04:30 AM
EE_Chris's Avatar
Default Re: Timing gun with no dial.... (d15b7racer)
Just point and shoot for the 3 red lines and adjust the dizzy as needed.
Old Jan 12, 2005 | 06:01 AM
Ri5e's Avatar
white mark is 0 degrees btdc
2nd closest to that is 14 deg. btdc
3rd is 16 deg. btdc
4th is 18 deg. btdc
usually the base timing is set at 16 deg. btdc.
Old Jan 12, 2005 | 08:30 AM
d15b7racer's Avatar
oh okay....so no dial means its set to "0" right? then if you had a dial and wanted 16 degrees you'd set it to 16 and shoot for the lone TDC mark? if thats correct you guys just made it way easier to understand. right on
Old Jan 12, 2005 | 08:43 AM
drdisco69's Avatar
Right. The extra marks on the pulley are for guns just like you have. Guns with a dial can "correct" for TDC, the white mark.
Old Jan 12, 2005 | 10:32 AM
d15b7racer's Avatar
Default Re: Timing gun with no dial.... (drdisco69)
thanks everyone......H-T to the rescue AGAIN!
Old May 7, 2006 | 04:10 AM
T-RO's Avatar
Had to bump this old thread cause it helped me out. I too had no idea what the **** did on the timing gun.
98bucket
Nov 21, 2010 03:57 PM
blackbndt
Oct 4, 2009 10:20 AM
littlegreenb18
Nov 12, 2005 06:54 PM
FredoSP
May 30, 2004 08:42 AM
powerfulperformance
Oct 20, 2003 04:58 AM
