Transmission Selection. D-Series Transmission gearing. Which is best for acceleration.
Old Jan 6, 2005 | 11:49 AM
wushubrian's Avatar
Default Transmission Selection. D-Series Transmission gearing. Which is best for acceleration.
Alright I have a 97 civic DX Hatch. I'm going to do a lot of motor work and stuff and I want to change the transmission. I know the DX transmission has real long gears and I wanted something that would be a better for acceleration. What D-series transmissions would be the best for acceleration. I was thinking of getting one from a 00 civic ex coupe. Any other suggestions or pro's and con's of each transmission. Thanks for the help it is greatly appreciated.
Old Jan 6, 2005 | 11:52 AM
Ricey McRicerton's Avatar
Default Re: Transmission Selection. D-Series Transmission gearing. Which is best for acceleration. (wushub
96-00 EX coupe if you want a factory transmission. Mistabone had a link in his signature to some crazy custom tranny that he built, but if you are asking this question, you probally aren't up to build your own.
EDIT: Pros for this tranny
Tightest gearing of any factory D series transmission.
Cons:
Still has long *** gears.
Old Jan 6, 2005 | 12:01 PM
a1320honda's Avatar
ok, not trying to be a dick, but use the search button, this has been covered more than a thousand times
https://honda-tech.com/zerothread?id=651870
http://home.cinci.rr.com/mistab0ne/tranny.html
https://honda-tech.com/zerothread?id=453997
just pulled those up real quick, hope that helps
P.S. z6 has beefy aluminum forks that are prone to cracking and breaking, the y8 tranny has steel forks, but they are thin steel with no structural support so the bend, i know, ive bent some, but never broke em.
Old May 3, 2005 | 10:11 AM
hondainspired's Avatar
i can vouch for the z6 pos alluminum forks... i broke one
Old May 3, 2005 | 10:55 AM
snatch's Avatar
For acceleration, the best stock tranny is the Y8 IMO.
Old May 3, 2005 | 11:51 AM
gabspeed's Avatar
use the serch this same question has been posted many times yes the y8 would be the best ratio of all d series same as z6 with slight difference on final ratio but its the same (y8 newer)
Old Feb 15, 2009 | 10:46 AM
Ej61z's Avatar
New User
I say the best D series tranny as far ad performance and acceleration would be the jdm D15B VTEC tranny with Factory LSD. They are hard to come by and and lil pricey but well worth it. Probably cost ya $400. I got me one.
Old Feb 15, 2009 | 11:05 AM
socallmechris's Avatar
i just rebuilt my ex tranny cuz i had the input shaft bearing go out on me. so i got an lx tranny to throw in so i could still drive. after having an ex tranny and go ing to the lx i hated it. first gear went to like 45 and second all the way out to 70. the 4th-5th were about the same, but it was slow as ***** to get there.
nowi swapped and have a b16 trans on my b20 but im gonna have to do something about that 5th
crzhrs
May 13, 2010 03:01 PM
Casp3r88
Aug 25, 2007 06:05 AM
jetblack
22
Nov 3, 2004 12:10 AM
PearlWhiteAccord
31
Jun 20, 2004 03:40 PM
bryfug13
Jan 14, 2004 12:05 PM
