what injectors do i get?
Old Jan 5, 2005 | 01:06 PM
jiggy's Avatar
Default what injectors do i get?
96-98 ek obd2.. jdm obd1 motor and ecu.. wanna get rc750cc injectors.. which ones do i get?
saturated or peak n hold?
high or low resistance?
do i need to get any special clips n ****?
thanks
Old Jan 5, 2005 | 01:08 PM
jlacoy82's Avatar
71.192.16.183
Uhh...........are you turboed/turboing? Or are you making 230-250+ HP on an NA motor?
If you answered no to both questions, the injectors you want are the ones already in there: OEM.
People will need more info; WHICH motor exactly, any other mods you have, any info other than what kind of engine harness you have and what obd motor you have. We dont even know if you are talking about a b or d series motor.
Old Jan 5, 2005 | 04:20 PM
jiggy's Avatar
Default Re:
98 ek obd2.. obd1 jdm gsr motor.. skunk2 obd2->obd1 harness for the obd1 ecu.. im going boost t3/t4, running 10-12psi daily, 15psi when racing.. jg intake mani and tbody..skunk2 valvetrain..
i wanna get the rc750cc injectors..
do i get saturdated or peak n hold?
do i need any special clips and adapter cables?
Old Jan 5, 2005 | 04:47 PM
MikeD718's Avatar
Default Re: Re: (jiggy)
well after i did a search for you https://honda-tech.com/zerothread?id=704760
if its a '92+ GSR you will need saturated
Old Jan 5, 2005 | 04:57 PM
jiggy's Avatar
Default Re:
So, which should I choose?
There are a ton of factors involved in this.
First, power level. If you're going big, there simply won't be a saturated injector that will support your power level. The largest common saturated injecotrs on the market are 550cc, with 440cc being a common "cap" in saturated size. Most boosted people run peak/hold setups for not only their availibilty, but also their ease of upgrading later on if so desired. simply swap the injectors. no need to re-wire again.
so.. i need to run peaknhold since i wanna run 750cc.. this means i have to get a resistor box n all that?.. do i need to get anything else?.. on the rc website it says if u have a 96+ car, u have to get an obd1 adapter or some ****.. but my motor is already obd1..
Old Jan 5, 2005 | 05:39 PM
2lua's Avatar
you just answered your own question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jiggy &raquo;</TD></TR><TR><TD CLASS="quote">
i need to run peaknhold since i wanna run 750cc.. this means i have to get a resistor box n all that?.. do i need to get anything else?.. on the rc website it says if u have a 96+ car, u have to get an obd1 adapter or some ****.. but my motor is already obd1.. </TD></TR></TABLE>
Old Jan 5, 2005 | 05:48 PM
snoochtodanooch's Avatar
why 750s, thats alot for you boost, and the FI forum would probably be better for the question.
Old Jan 5, 2005 | 05:59 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jiggy &raquo;</TD></TR><TR><TD CLASS="quote">So, which should I choose?
so.. i need to run peaknhold since i wanna run 750cc.. this means i have to get a resistor box n all that?.. do i need to get anything else?.. on the rc website it says if u have a 96+ car, u have to get an obd1 adapter or some ****.. but my motor is already obd1.. </TD></TR></TABLE>
i'm using 750cc's without an injector box!!!
Old Jan 5, 2005 | 06:15 PM
jiggy's Avatar
Default Re: Re:
my tuner recommended 750's..
SiRCivic707
Sep 12, 2015 05:28 PM
Hardrath_R
Aug 7, 2012 11:35 AM
bettsbanger
Feb 4, 2009 11:12 AM
Turbo_y8
Jan 20, 2006 09:19 PM
ekb18cCivic
Nov 15, 2003 05:12 PM
