Obd1 injectors in an obd2 motor
Old 08-06-2012, 01:26 PM
Hardrath_R's Avatar
Default Obd1 injectors in an obd2 motor
I just bought an obd2 jdm GSR B18c from hmotors to replace my old GSR. Thing is hmotors only had obd2 motors and not obd1 like I need. I was told to convert the obd2 motor to obd1 motor I need an obd1 alternator and dizzy which I have. But I do not have obd1 injectors. My question is, which injectors do I need to make it work, will any obd1 injectors work in a jdm obd2 engine?
Old 08-06-2012, 02:01 PM
angryhillbilly's Avatar
Default Re: Obd1 injectors in an obd2 motor
all b series injectors are exactly the same. apart from the clips that the harness plugs into.
Old 08-06-2012, 04:48 PM
Hardrath_R's Avatar
Thanks for te info. Just wanted to make sure before I spend the money.
Old 08-07-2012, 11:12 AM
qais_vtec's Avatar
i have a set of obd0 injectors from my old b16a1 engine (UKDM), i was going to put them in my b18c6 itr (as i dropped one and broke the tip) but iv managed to cross reference the part numbers but they are different, so i then cross referenced the numbers with an obd1 set (from a b16a2 vti ukdm) and yet again all three sets are different. i dont know whats different about them because they all look the same visually and thought they all were 240cc/min.
Old 08-07-2012, 11:35 AM
kyden's Avatar
obd0 injectors require a resistor box, obd1 and obd2 injectors are the same but have a different connector on it and neither require a resistor box.
jlowellintegra
01-03-2014 06:35 PM
roycivic92
05-26-2010 11:22 PM
Edul59
07-27-2009 09:53 AM
Quick Reply: Obd1 injectors in an obd2 motor
