Engine light goes on and off
Old Jan 4, 2002 | 10:58 PM
d0nkeyxPunch's Avatar
Banned
Default Engine light goes on and off
The engine light on my cluster goes on and off over and over again. So I checked my oil and there were sufficient oil. So I am guessing that the sensors are messed up. Can someone help me out? It is really bothering me and I drive about 30 min every other day to work. Thanks.
Old Jan 5, 2002 | 06:05 AM
VaporTrail's Avatar
New User
Default Re: Engine light goes on and off (FastxCivic)
I *think* you are either grounding out the service connector, or the cel is for bad ecu. How does the car run/idle?
Old Jan 6, 2002 | 11:55 PM
Banned
Default Re: Engine light goes on and off (VaporTrail)
I am running a chipped P28. The car is running rich for a while. Can this be the problem? These days, the light has not come on.
Old Jan 7, 2002 | 03:42 AM
irev210's Avatar
naw the problem is most likely a defective sensor or a loose wire.
To isolate the problem, when the check engine light is on, look at the ECU and see what code you are throwing. Once you have done that, check the sensor and the wire to make sure that the wire didnt get hot and melt, or that the sensor is in good condition, ideally, visually inspect the wireloom that the wire is in and see if the plastic casing has gotten melted or corroded, if not go to a junk yard and buy a sensor for the part that needs replacing
I hope that helps
Old Jan 7, 2002 | 11:23 AM
Katman's Avatar
what year is your car? if it's a 96+ civic, try running your stock 96+ civic ECU and see how that runs and if it shows the same symptoms - if it doesn't show the symptoms, then its the P28 ECU. Have you also checked to see which check engine code it's throwing ?
Old Jan 7, 2002 | 11:58 AM
Banned
Default Re: Engine light goes on and off (Katman)
My car is a '99 Civic SI. Its not the check engine light, its the engine oil light. I don't have my stock ECU which really sucks. My engine oil is at a normal level, but this light keeps on coming on and off. The light started coming on after I used 10w30 rather than my usual 5w30. Not sure if different type of engine oil could actually trigger this problem.
Old Jan 7, 2002 | 04:55 PM
Katman's Avatar
nah.
a change in oil type's wouldn't make the oil check light come on like that.
Maybe you have something clogged up
Old Jan 7, 2002 | 09:25 PM
Banned
crap...this sucks. I'll get it checked out by a professional. Thanks
7mile
Jul 1, 2010 02:10 PM
Gyoung145
Sep 30, 2006 05:58 AM
racingcrx
13
Sep 10, 2006 12:52 AM
Groove_D
Jan 4, 2005 01:13 PM
PhuckinHondas
Sep 18, 2002 09:37 PM
