Blockguard? should or shouldn't i use?
Old Dec 8, 2004 | 06:36 AM
LilCivic04's Avatar
Default Blockguard? should or shouldn't i use?
i am rebuilding my z6 with
8.8:1 compression wiseco pistons
je rings
scat rods
all clevite bearings
gude ported head
crower turbo cams
skunk2 intake manifold
turbonetics t3/t4 turbo kit
do you think its wise for me to use a block guard? i've heard yes and no on other threads but i need to know if i should on my application. what are they good for? i am currently using my stock sleeves. whats a good block guard to use? can i install it in myself of do i have to have a machine shop do it?
Old Dec 8, 2004 | 11:37 AM
RyanEJ8's Avatar
Default Re: Blockguard? should or shouldn't i use? (LilCivic04)
I've been using a GE blockguard for a year and a half now with no problems. You can install it yourself, just make sure to file fit. Don't force it.
Old Dec 8, 2004 | 11:43 AM
ComputerJLT's Avatar
where did u get clevvete blahblah bearings for a honda d?
how much were they and are they tri-metal bearings?
and to answer your question i would not use a block guard. I bought some block posting studs from endyne and am gunna use those
Old Dec 8, 2004 | 12:22 PM
eddyboy's Avatar
Default Re: Blockguard? should or shouldn't i use? (ComputerJLT)
There are so many different opinions about Blockgaurds. Just do what I did read about it and then come to your own conclusions.
After doing the research I went with a GE blockguard. No overheating problems.
GL
Old Dec 8, 2004 | 06:50 PM
JdmEKCivic's Avatar
Default Re: Blockguard? should or shouldn't i use? (eddyboy)
blockguards are funny some people have had problems using them they said that the blockguard and the sleeves stretched at diffrent temps and that lead to a cracked cylinder wall
Old Dec 8, 2004 | 07:47 PM
1slowcrx's Avatar
Default Re: Blockguard? should or shouldn't i use? (JdmEKCivic)
in my opinion,the stock sleeves can hold up just as much power as a motor with a block guard.it's all in the tuning.theres people on this board that have made 400+ on stock sleeves with no blockguard.put that money in tuning.thats just my .2cent
Old Dec 9, 2004 | 07:39 AM
AsianMullet's Avatar
Default Re: Blockguard? should or shouldn't i use? (1slowcrx)
GE BG with no problems
Old Dec 9, 2004 | 07:53 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEKCivic &raquo;</TD></TR><TR><TD CLASS="quote">blockguards are funny some people have had problems using them they said that the blockguard and the sleeves stretched at diffrent temps and that lead to a cracked cylinder wall </TD></TR></TABLE>
Those people had other problems and blamed it on the blockguard.
diouf
Sep 30, 2011 08:07 PM
top end tuner
Dec 14, 2008 09:00 PM
leprican22
Sep 24, 2005 06:11 AM
burley40
Jul 26, 2005 07:33 PM
z6
May 10, 2004 09:57 PM
