clean throttle body? do u know how?
i know people use car cleaner and just spray it into the t/b but i was wonderin what steps u guys take to clean ur throttle body while its off the car. what kind cleaner do you use? i just pik up a throttle body and i wanna clean it reallly good but i just need some advice of what to do and not to do. Pics could b helpful on products or steps to clean...reply whatever u can if u you think its help ful
way i do it is get a soft tip brush (toothbrush) and some good tb cleaner. i use valvoline synthetic stuff. works like a charm
just spray it while car isnt running swirl the brush around, spray a bit more then start the car up open the throttle and spray for about 5/10 sec to clean it all out
like I said valvoline makes a synthetic throttle body cleaner. its the same thing as a carb cleaner. you can find it anywhere. wal mart, autozone etc
All you need to do is use throttlebody (T/B) cleaner (spray can) it doesn't matter which brand you choose just go to a good auto parts supply store, they will have it. Spray some (you dont need alot) in your T/B opening and brush it a bit with an old soft tooothbrush and wipe out the opening with a rag. It is not necessary to remove the intake manifold (I/M) to clean that to, but if the parts off the motor already than clean the I/M the exact same way.
T/B cleaner is DIFFERANT THAN Straight CARB cleaner... carb cleaner dries out seals... T/B cleaner Doesn't.... just go buy a can of Sea Foam Deep Creep and Sea foam your car too ... cost all in all 10 bucks
so just use the sea foam products to clean the throttle body? how come sea foam is so good the t/b? is it made for t/b claner?
speedehatch
Jan 19, 2004 02:28 PM
