clean throttle body? do u know how?
how to clean throttle body?
i know people use car cleaner and just spray it into the t/b but i was wonderin what steps u guys take to clean ur throttle body while its off the car. what kind cleaner do you use? i just pik up a throttle body and i wanna clean it reallly good but i just need some advice of what to do and not to do. Pics could b helpful on products or steps to clean...reply whatever u can if u you think its help ful
Re: clean throttle body? do u know how? (Civicr2gs5)
way i do it is get a soft tip brush (toothbrush) and some good tb cleaner. i use valvoline synthetic stuff. works like a charm
just spray it while car isnt running swirl the brush around, spray a bit more then start the car up open the throttle and spray for about 5/10 sec to clean it all out
like I said valvoline makes a synthetic throttle body cleaner. its the same thing as a carb cleaner. you can find it anywhere. wal mart, autozone etc
Re: how to clean throttle body? (Civicr2gs5)
All you need to do is use throttlebody (T/B) cleaner (spray can) it doesn't matter which brand you choose just go to a good auto parts supply store, they will have it. Spray some (you dont need alot) in your T/B opening and brush it a bit with an old soft tooothbrush and wipe out the opening with a rag. It is not necessary to remove the intake manifold (I/M) to clean that to, but if the parts off the motor already than clean the I/M the exact same way.
Re: how to clean throttle body? (EGgsrAM)
T/B cleaner is DIFFERANT THAN Straight CARB cleaner... carb cleaner dries out seals... T/B cleaner Doesn't.... just go buy a can of Sea Foam Deep Creep and Sea foam your car too ... cost all in all 10 bucks
Re: how to clean throttle body? (cueballsi)
so just use the sea foam products to clean the throttle body? how come sea foam is so good the t/b? is it made for t/b claner?
speedehatch
01-19-2004 02:28 PM
