What is this ring for?.. Wastegate
Old Nov 21, 2004 | 04:11 PM
endlessdv's Avatar
Default What is this ring for?.. Wastegate
This metal ring came with my Tial 38mm wastegate.. I was wondering what it was used for and if I need it?
Old Nov 21, 2004 | 04:14 PM
PrettyLude's Avatar
its used to seat the wastegate right, without that it won't build boost
Old Nov 21, 2004 | 04:15 PM
PrettyLude's Avatar
its called a firering
Old Nov 21, 2004 | 04:21 PM
StrokedPSI's Avatar
Default Re: (PrettyLude)
yes you need it, it goue between the WG and the flange.
Old Nov 21, 2004 | 04:24 PM
endlessdv's Avatar
Default Re: (StrokedPSI)
Well I have the wastegate on my car. Do you guys think this could be the problem to my leaky idles and not building up boost to the set spring pressure?
Old Nov 21, 2004 | 04:27 PM
Casey's Avatar
Default Re: (siamturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siamturbo &raquo;</TD></TR><TR><TD CLASS="quote">Well I have the wastegate on my car. Do you guys think this could be the problem to my leaky idles and not building up boost to the set spring pressure?</TD></TR></TABLE>
lol probably
Old Nov 21, 2004 | 05:19 PM
adictionbass's Avatar
Default Re: (Casey)
wow...... id put that in
Old Nov 21, 2004 | 05:20 PM
camp1320.com's Avatar
Default Re: (adictionbass)
you will leak alot of boost without that.. that seals the vavle on the flange it wont fit alll the way until you tighten the bolts down.. you need to compress it
Old Nov 21, 2004 | 05:46 PM
endlessdv's Avatar
Default Re: (camp1320.com)
Thanks guys... I took my wastegate out and put it on.... It sounds great and holds boost and is faster now..
Old Nov 21, 2004 | 05:48 PM
Old Nov 21, 2004 | 06:30 PM
ScottEK's Avatar
Without that ring in you can visually see right around the valve which would mean all that exhaust gas would pass right by, you'd constantly be bleeding off exhaust pressure through your dump tube instead of spooling your turbo.
GSRswapandslow.
Jun 17, 2004 01:49 PM
specie
Feb 5, 2004 09:38 AM
QWKPHKR
Dec 21, 2003 08:31 PM
highmilehatch
Oct 15, 2003 07:44 AM
