How can I tell if my Tial WG is actually a 38mm like stated??
Hey guys, does anyone know how I can tell if the Tial WG I bought is actually a 38mm and not a 35mm...
Thanks
Thanks
New User
Re: How can I tell if my Tial WG is actually a 38mm like stated?? (rjardy)
Does it have the aluminum top to it with the nice curvy shape to it?
Let me find examples:
My 35mm Tial:
THIS is a 38mm:
My 35mm Tial:
THIS is a 38mm:
Re: How can I tell if my Tial WG is actually a 38mm like stated?? (SpdFrk)
well according to TiAL , the more boost you are running , the smaller wastegate u going to need
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL »</TD></TR><TR><TD CLASS="quote">Flow capacity. Contrary to popular belief, larger higher HP applications do not necessarily require the largest wastegate available. The lower the boost pressure you are gunning for the larger your wastegate needs to be. An engine/turbo combination that is set to 25+psi has a smaller wastegate flow requirement than the same application set to 7 psi. This is because the wastegate is used to lower the boost not raise it, the lower the boost pressure is set the more flow the wastegate must allow.
Re: How can I tell if my Tial WG is actually a 38mm like stated?? (Day Walker)
the 38MM has a bowl kinda discharge section where the gasses exit. the 35Mm is more of an rectangal.
BluLuder
09-13-2001 04:38 AM
