update on my B18C1 problem.
Old Dec 23, 2001 | 10:41 AM
91DA9's Avatar
Default update on my B18C1 problem.
You might remember my probelm from here https://honda-tech.com/zerothread?id=104340
Well I took the valve cover off and turns out my timing belt is loose! Could that make the sound that I described or is the sound responsible for the belt being loose? I checked the belt like 5000 miles ago and it looked new. Isn't there a tensioner pulley on that Timing belt drive? Could that be making the sound?
Also I went to try to get the broken studs replaced at NAPA and they don't have them. Does anyone know where to get them besides a dealer?
Old Dec 23, 2001 | 10:59 AM
OneThirtyEight's Avatar
Default Re: update on my B18C1 problem. (94IntegraGSR-OVR)
what studs?
Old Dec 23, 2001 | 11:13 AM
91DA9's Avatar
Default Re: update on my B18C1 problem. (97blackteg)
the studs that go through the valve cover and into the head but then have a smaller size for the grommet and nut for the valve cover.
Old Dec 23, 2001 | 03:41 PM
91DA9's Avatar
now i lost my ******* keys!
Old Dec 23, 2001 | 08:08 PM
RJL's Avatar
RJL
New User
dude your a mess!
Old Dec 24, 2001 | 12:00 AM
ingrate's Avatar
25 Year Member
just get them from the dealer and next time, try not to overtighten the nut. i think they were like $6-8 each.
and they do sell these neat little pager things you hook up to your keys in case you lose them chill out and have a beer man
Old Dec 24, 2001 | 10:30 AM
91DA9's Avatar
Default Re: update on my B18C1 problem. (In7egrity)
ok.
I found my keys and the car made the sixty mile trip to my friends garage without any valves touching any cylinders
I got my valve cover off and my timing belt is definitely loose. How can I adjust the tensioner and make sure it is not too tight?
BTW: thanks for the beer but i had some Vodka last night instead
Old Dec 24, 2001 | 11:33 AM
ingrate's Avatar
25 Year Member
there should be only about a half inch of play when you wiggle the belt either way
roadsqueegy95
15
Jun 7, 2012 09:22 AM
bdmlilburn
Jul 24, 2011 07:54 AM
misha
11
Nov 5, 2006 01:01 PM
axtran
May 14, 2006 09:55 AM
